Originally posted by KILLER-T
I got eveything bolted up and started her up and nothing so i rang up ***** and he told me the car wont run setup like that and i would need a new ecu like autronics
Err , why ?
Power FC is fully adjustable. Only difference is that it uses Airflow voltage and tps to control whereas Autronic uses map and tps to control.
Why can't you tune the Power FC ?
Cheers
Ken
Killer,
Glad we encouraged you. I don't want to be rude about that guy, cause I know lots of people use him, but he doesn't know much IMHO.
Plenty of tuners around, so give them a go. But Steve does mine and looks after my friends:D
See'ya:burnout:
Originally posted by GTS-t VSPEC
Killer,
It's a good job that you we asked you why you needed it, otherwise you would have been seriously ripped-off. If you get advice, always ask for another opinon, the forum is a great place for that:D
See'ya:burnout:
Agreed,
Killer is the TPS connected? as I cant recall seeing it in your pict's.
Damqik
'Hello I'm an agent for Ripoff's Inc.'
Ask the guy one more time if the PFC will work (don't tell him it is) then if his answer is the same tell him you got it to work and tell him what you think off his lies.
Guest KILLER-T
I have the factory nissan TPS on the ford throttle body i asked mario if he could make a bracket to mount it on and it seems to be working well. The noise you get from the plenum sounds wicked i think it must be because of the thinner alloy its made from or something like that but it sounds nice
I got a Sub-Zero plenum + fuel rail at the end of last year... Very nice, good sized Bell-Mouths... I'm running a EF Throttle body with the Ford TPS, but Glenn at C-Red took the Ford Throttle linkage off and put the standard Nissan one on... I'm running Autronics SM2 V1.94... The plenum is awesome!!!!
DAMQIK GTS-T is right about that solenoid...
    • PULSAR PSR2860R 0.86A/R or 0.64 GEN 2 Turbocharger Both are -50*67mm 8 blade billet compressor wheel Cheers
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe.....EDIT... nope, the Kraken is a cast jobbie, the REv9 uses welded up stainless, plus $8000 AUD before shipping, installation and tuning) Where else in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit that Pulse fitted, and it was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
