Guest 40th-edition
Pinging is the engine detonation the fuel to early on the stroke causing the noise!
such as if u use unleaded instead of premium.. when it goes hot the fuel will pre ignite and cause this.
u will hear a noise like a knocking or loud buzzing or how ever u want to describe it.
to resolve it try using a higher octain fuel.. or u can get an addertive which helps (its pritty much octain)
u should beabe to notice it when u r reving high and if the engine makes a weird noise.. ushaly atr high revs ( around 5000 depending)
hope this helps!
https://www.sau.com.au/forums/topic/129541-what-is-pinging/#findComment-2395908
Ping is pretty much a shortened term for PRE-IGNITION. I kinda sounds like a shaker in a spray can but more dull. As above but a few things to add.
Pinging can be caused by ignition timing too far in advance, hot spots in the cylinder head (usually caused by dodgy porting), lean fuel mixtures or not enough octane rating in the fuel being used. All of these things can cause the fuel/air mix to pre-ignite.
To rectify it you need to find out which one is causing the problem and alter it. Most of the time it is poor fuel quality or ignition timing. You will find that it will ping more so when the engine is producing most of its torque so it will disappear before 6000rpm most of the time.
https://www.sau.com.au/forums/topic/129541-what-is-pinging/#findComment-2395957
uneven combustion causing hot spots and percusion on the pistons-can be caused by many factors or combination of these-will result in the end of an engine if it continues over time. Warning - an engine can be knocking and you wont detect it with the human ear so always have it tuned correctly by a pro. So many backyarders chuck on a big turbo and other mods then shoot the boost through the roof and drive around without a good safe tune on it-then Ka Boom...wallet deflates :D
https://www.sau.com.au/forums/topic/129541-what-is-pinging/#findComment-2395981
Can also have piston knock, caused by too loose clearances when an engine is rebuilt, and just under load the piston can rattle on power stroke, even when fuel is good quality and timing isnt too far advanced. So having a good tight engine helps keep that form of knock to a minimal level.
Our old rb25, destroyed the ringlands off std pistons, and we had a race meeting the next weekend...out she came quick rebuild with some acl forgies and new bearings and usual crap, went for tuning and it wouldnt stop knocking, take all the timing out, loads of fuel no boost and it would still knock. go figure.
https://www.sau.com.au/forums/topic/129541-what-is-pinging/#findComment-2397310
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
