  • 2 months later...
  • Replies 130
  • 5 weeks later...
  • 3 weeks later...
Hey man! thanks for this excelent post! I was meant to reply ages ago. but i forgot to after i installed. Instructions were a breeze to follow. With my unit The electric antenna stays down when not in use for those interested. ;) Thats all. Thanks again! Cheers!
  • 1 month later...
  • 4 weeks later...
ANybody know about the pocket - close to $40 is too much
hey ben, before u ask AGAIN :lol: i have had a look at a few different pockets and all nissan ones i have seen seem to bolt on in the same places. best bet would be go to a wrecker a get one from a recent as possible pulsar.
Thanks Siks - Im going to pull it apart today and put the new deck in then add a pocket to suit.
Cheers! :)
you have to put the pocket in at the same time as you put the cd player in, because you have to pull everything apart again if you want to put a pocket in later (like me!) :angry:
If interested, I wrote up a guide VERY similar to this one, but possibly with more pics and a bit more detail. (and removing wiring)
http://srandy.com:81
The pics will be horribly slow because it's got a slow connection.
Link works now :)
Funny thing is my fascia fits whenthe side metal backets are on...however when I go to install it the skyline instrument surround won't go down over it (So I guess my unit must be sitting further out in relation to the bracket causing this fouling. Maybe I'll see if there is another spot I can screw it into. Only other option is to chisel out the fascia but in my case so it sits over the top of the black skyline insrument surround...
Good guide there!
Ah, then use this guy's guide, and simply drill some new holes in the bracket a bit further BACK, so the HU facia can sit behind the instrument surround. Should look very tidy if you do that =-]
I was going to do this before I read this guys article, but I needed to bring it back about 2mm... you can't really drill a hole 2mm back, so my only option was to widen the holes horizontally, much like the CD-ROM screw-holes in a PC case for adjusting the depth of the CDROM. Trimming a little of the facia was heaps quicker.
I just went to Nissan and got a brand newie pulsar pocket - fits nicely - other nissan ones may have fit but couldndnt be bothered checking.
$33 - a lot for a bit of plastic but looks good now.
Though while Im at it I've decided to peel all the rubber/silicone coating off the dash surround and paint it. I'm going to use Matt Black paint ($3 at pig W). The paint I have gives a textured type feel. I did the drivers side power window surround about 6 months ago - looks good and has held up to the test of time so far.
I peeled all the material off - used a bit of thinner - the occasioinal rough up with the file to disturb it and fingers to get it all off.
The vents dont seem to come out easy - there is one sort of rivet type screw to stop you taking these out - Might tape them up before the spray
Thanks guys!
PS Is it an easy fix while I have everything off to stop the air con click clicking when you change temp and at random times?
Edited by benl1981
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
