  • 1 month later...
  • Replies 130
But that would be useless to most people without pics :)
NS2500: We have excactly the same headunit in our car, I'm going to take half of it out again so I can spray paint the plastic surround black. The grey colour doesn't match with my dash.
  • 1 month later...
Howdy, just though you might like to update the link, as I get a 404 - Error not found when trying to load it!
Also I have just bought an R33 and it did not come with a stereo, as the guy wanted an extra $2000 for it, so now I have put just a cheapy in to get buy until I can get a half decent one, but for some reason, the dash clock now stays on all the time? I have unplugged it so it does not drain the battery, but can someone tell me what I have done wrong?
Thanks,
Ska
Greg,
Looks AWESOME! I am going to take your lovely wiring guide now and try to see what wires are connected to what as there is definatly something wrong as I could not get my stereo to work off what I thought was acc power, so I just bunged it on constant power, which is alright, just have to remember to turn it off, but an interesting side affect was that my dash clock now stayes on, so i just unplugged it.
But now I can really see what is what, THANKS!!!
Ska
I am such a dumbass..... was in such a hurry to change CDs today I accidentally missed the slot and shoved it into the R33 - like really INTO the car.
*sigh*
quick question... anyone know how to retrieve it without having to drag out the whole deck??
Use the force???
I once found a Michael Jackson CD that had been lost in a car this way... Who knows what you might find behind there :crazy:
  • 3 weeks later...
is this the same for installing an R32 deck. mine doesn't sit properlyt and I found out it doesn't have the standard brackets. gettingh them from Just jap. bought a new sleeve from nissan. if I follow the R33 guide will it fit the same? I can take the dash apart myself easy enough, so is fitting the same
mark
mark
Fitting is straightforward, eg. screw the unit in where it fits! As to the wiring I'm not so sure. Does anyone know if the R32 wiring is the same? S1 and S2 R33 are the same.
Hi NS2500,
Thank you for your AeroPro links, they were most informative. My only question is this. I had as factory a tape and CD player, but it appeared that there were two wiring looms for the car.
I can only presume one is for the pwr, remote etc, and the other is for speakers etc. Given this, do you know where I can find the other loom (model no. etc,) to plug into the second factory adapter?
Thanks heaps for your help.
Has anyone installed the DEh-8500MP or DEH-850MP!!!!
I installed it yesterday but the outside bracket was too large to fit...does this mean i have to pull the headunit out further from the chasis so the frame can fit???
Thanks in advance
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
