  • Replies 130
Has anyone installed the DEh-8500MP or DEH-850MP!!!!
I installed it yesterday but the outside bracket was too large to fit...does this mean i have to pull the headunit out further from the chasis so the frame can fit???
Thanks in advance
I'm guessing you mean the surround, around the outside of the unit? If you have a look, I had to redrill the factory bracket back about 10mm to get the whole surround to fit under the console surround.
Nice guide bruv! Just installed mine, how hard is it to throw in the pulsar tray?  What year Pulsar is it from? Is it a good fit? How much $$$? Ive just got an empty space there! Looks ugly as!!
Cheers!
I believe it was from the current model, it's just a standard Nissan part which they would use across all Pulsars I guess.
Thanks in advance
I had the same problem. I used a mini angle grinder to shave a few mm off each side of the surround and now fits perfectly.
nice tut - but here's what happened to me last week...
i worked out how to pull her apart myself - got it out and cut off the stocko JAP steareo connectors..
I used a test lamp to find the constant 12V and switched 12V, I then used a AA battery to locate speakers wires.
I hooked it all up using auto elect clips with crimp tool...
when I had it all up and going - the unit wouldn't light up!!! I have no idea why - all fuses are fine and there is power there (test lamped) - BTW, the colours are different to mine
  • 1 month later...
i got a a pulsar that i use for sound comps which currently has a sony XAV7W with DVD player as my head unit, kicker revolution 6 inch spilts kicker 6x9 and two 15inch kicker comp Vrs running via two Kicker 4 channel amps. Are these subs better suited to a ported/vented box or a sealed enclosure, as i listen to R&B music i like the deep sub bass style of the music to pump from the sub. WHICH SHOULD I USE?? SEND ME A MSG TO TELL ME
CHEERS
I'll post this on the forum rather than a message - the whole point of a public forum is to share knowledge (or lack thereof :thumbsup:)
With that sort of cone area, I would definitely put them in a sealed box. With two 15s you don't really need ported boxes to make big low-down bass.
If you're going for SPL though, a properly set up, ported box with give you the numbers. Keep in mind that with a ported box, because you have to tune the ports for a narrow frequency range, sound in that frequency range will be much louder than the rest of the range. If you play a sine wave from, say, 10Hz through to 150Hz, and you have your box tuned to 25Hz, the sub will be noticeably louder at 25Hz than at 50. Yes, you can 'tune' a sealed box to give better response at a given frequency range, but overall they are a much smoother, more consistent setup.
In a nutshell
Sound quality: Sealed
Volume: Ported
  • 4 weeks later...
Nice work mate, This is probably the most detailed installation guide i have seen......very neat
Ive actually got a kenwood double din in my 33 but it doesnt play CD R's
so im getting rid of it and just installing a standard cd palyer, so ill definately refer back to this guide.
Cheers!!!
  • 1 month later...
By the way the red/purple wire is luminance/dimmer. You can find the same wire on the cigarette lighter. Also im allmost positive that is the same deck (the one removed in the guide) that you will find in a 98 nissan patrol.
hey,
great guide mate will use it 4 sure...
does ne1 know how 2 get the bak parcel tray out of these 33's so i can put better speakers in..just confused me and gave me a head ache...
Yep - you have to pull the back seat out (do a search, I think there is a how-to on that somewhere), and pull the grilles off the speakers and remove the child restraints. Between the speakers there are a couple of clips, my preferred method of getting these off is to slide my hand under the parcel tray carefully (palm up) and feel around until you find the clips. Once you've found them, get your fingers as close to the clip as possible and push up until it pops out. Don't push on the clip itself because it'll probably push through the weak fibreboard parcel tray. Repeat for the other clips (mine has a total of three if I remember correctly). Then just pull the parcel tray out.
  • 4 weeks later...
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
