  • 2 months later...
  • Replies 130
  • 5 weeks later...
  • 3 weeks later...
Hey man! thanks for this excelent post! I was meant to reply ages ago. but i forgot to after i installed. Instructions were a breeze to follow. With my unit The electric antenna stays down when not in use for those interested. ;) Thats all. Thanks again! Cheers!
  • 1 month later...
  • 4 weeks later...
ANybody know about the pocket - close to $40 is too much
hey ben, before u ask AGAIN :lol: i have had a look at a few different pockets and all nissan ones i have seen seem to bolt on in the same places. best bet would be go to a wrecker a get one from a recent as possible pulsar.
Thanks Siks - Im going to pull it apart today and put the new deck in then add a pocket to suit.
Cheers! :)
you have to put the pocket in at the same time as you put the cd player in, because you have to pull everything apart again if you want to put a pocket in later (like me!) :angry:
If interested, I wrote up a guide VERY similar to this one, but possibly with more pics and a bit more detail. (and removing wiring)
http://srandy.com:81
The pics will be horribly slow because it's got a slow connection.
Link works now :)
Funny thing is my fascia fits whenthe side metal backets are on...however when I go to install it the skyline instrument surround won't go down over it (So I guess my unit must be sitting further out in relation to the bracket causing this fouling. Maybe I'll see if there is another spot I can screw it into. Only other option is to chisel out the fascia but in my case so it sits over the top of the black skyline insrument surround...
Good guide there!
Ah, then use this guy's guide, and simply drill some new holes in the bracket a bit further BACK, so the HU facia can sit behind the instrument surround. Should look very tidy if you do that =-]
I was going to do this before I read this guys article, but I needed to bring it back about 2mm... you can't really drill a hole 2mm back, so my only option was to widen the holes horizontally, much like the CD-ROM screw-holes in a PC case for adjusting the depth of the CDROM. Trimming a little of the facia was heaps quicker.
I just went to Nissan and got a brand newie pulsar pocket - fits nicely - other nissan ones may have fit but couldndnt be bothered checking.
$33 - a lot for a bit of plastic but looks good now.
Though while Im at it I've decided to peel all the rubber/silicone coating off the dash surround and paint it. I'm going to use Matt Black paint ($3 at pig W). The paint I have gives a textured type feel. I did the drivers side power window surround about 6 months ago - looks good and has held up to the test of time so far.
I peeled all the material off - used a bit of thinner - the occasioinal rough up with the file to disturb it and fingers to get it all off.
The vents dont seem to come out easy - there is one sort of rivet type screw to stop you taking these out - Might tape them up before the spray
Thanks guys!
PS Is it an easy fix while I have everything off to stop the air con click clicking when you change temp and at random times?
Edited by benl1981
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
