  • Replies 130
My A/C clicks too... someone once said that it was on the heaterbox that the problem is. I still get different temps and everything, so I haven't been bothered to look into it. Let me know if you find the source of the cause!
Interesting about the dash plastic... I bought my car with none on it. It's just a really rough texture atm. If I try and clean it with kitchen paper, it shreds it. =-/
I want to paint it, but I CBF pulling the whole thing out and painting it. =-[
I'm suprised yours is rough. When the silicon/rubber comes off it is incredibly smooth and glossy - just balck palstic.
Only did it cause I had all the bits 9/10s out. Should have taken it off to start with - a lot easier getting the stereo in and out..
My ac works fine etc - just thought id ask in case there was a simple fix , while I had things out.
Heh... we don't know! I thought it was normal! =-[
Ben: yeah.. dunno man.. it hasn't been painted before. I think the clear was taken off ages ago, and the sun had its way with it
  • 2 months later...
  • 1 year later...
is it necessary to disconnect the -ve terminal of the battery b4 installation?
Yes, its a very good idea to avoid shorts + sparks while cutting and joining wires.
If you use a 10mm (i think) spanner it'll only take 30 seconds to take it off.
why does your air-con click, mine does the exact same thing and i'm art a aloss as to where to start with it.....
whewn I asked my mech about the air con clicking he said it was just the condenser turing itself on and off...
http://www.aerpro.com.au/list.php?pcode=AP...o=&cat_sno=
that's the wiring harness adaptor that we can use for connecting aftermarket head units to the factory loom...dont know what its priced at though..
Edited by traman18
  • 3 months later...
I just bought this stuff all at Autobarn, mainly because I'm lazy. Its a 2 min walk from where I work!
Wiring Harness (AP7550) - $19.99
Diversity Adaptor (AP348A) - $12.99 ***NOTE*** There is a AP348B, looks similar and costs the same, but not the same part. I made this mistake :)
Facia Kit (FP997417) - $37.99
Not 100% sure if the Facia Kit will work (it should, previous posts said 1995 and older Nissan parts would do... right?), will find out and post it up :O
EDIT - Decided to post up all the prices for all to see, and laugh at how ripped off I may have been :laugh:
Edited by Cassbo
  • 2 months later...
great stuff mate very good guide! will be reffering to this again very soon. i already have an aftermarket HU but will be upgrading to a double din 7" screen, so in theory the current loom will hook straight up to my new HU? out with the old in with the new!
  • 3 months later...
Great thread, the only place I found to have the correct wiring harness was Autobahn, Repco was out of stock and Supercheap auto don't have them in any store in Vic for the R33.
It was about $28 for harness and radio connection adapter.
  • 2 months later...
  • 4 weeks later...
dude good find. want to do wat theyve done in step 5 (wiring ). ive currently got the plug thingo but want to use the distribution terminal block instead. only problem is that i dont know wat connects to wat after ive cut it. looks like some colours dont actually connect to anything :S anyone got a DIY?
  • 8 months later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
