  • 1 year later...
  • Replies 130
  • 1 month later...
couldnt find anything at all. have an S1 skyline and the colours on the diagrams from these sites dont match the colours of the wires in my car? Im no novice to audio installation and have installed plenty of decks DIY style with the use of proper colour accurate diagrams.
can anyone confirm or shed some light as to what the colours on the S1 R33 are? or have a DIY pic I can look at?
http://www.installdr.com/Harnesses/Nissan-Wiring.pdf
i haven't used this so... yer
it would be a good idea to buy a multimeter there only like $10 u dont need to get a $250 one
and wile ur they get a CRO that way u can eliminate clipping :laugh:
but seriously multimeter
  • 1 month later...
  • 6 months later...
http://replay.waybac...ovesystems.net/
but the images don't load.
I'd be happy the throw it online if Greg Rudakov where to email me the files
Would also like the photo's for the install since they do not load... email = [email protected]
Thanks ~Tommy
  • 3 months later...
  • 6 months later...
  • 3 years later...
Revival of the thread - I have tried different combinations of wiring a JVC aftermarket head unit in my R33 GTR, but seems it doesn't want to work. I can turn the deck on, and can hear sound from the front speakers, but nothing from the rear ones, and not sure why there is bass coming through. Possibly because the factory amplifier is not connected? I dont know which wire is for the amplifier. According to the link, the amplifier wire should be at slot B on the smaller plug, but there is no wire there.
How do I identify it? All the wires on both plugs are accounted for.
Would appreciate any help you guys can offer me.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
