Good call/find Howie !!
I've had the same stains on my back window since the last Skid Pan day ( they use bore water at the Skid Pans which stains / eats into your car if left to dry ).
Couldn't get #4 Heavy Cut ( Meguires told me they don't sell it any more ) so I got #2 Medium Cut and it worked a treat :D Needed a bit more elbow grease but it cleaned up great. I then used windex/metho to clean the glass and then hit it with a coat of Rainex. Forgot glass could look that good !!
Cheers :O
Glad to hear mate! :D
Heavy Cut Cleaner was replaced by Diamond Polish series. I ended up getting the Diamond Polish. Basically anything with a strong cut and a diminishing abrasive will work. I'll grab some pics sometime this weekend after i've cleaned up all my windows.
End results with Diamond Cut Polish. Took two attempts to get rid of it completely.
Comparison ... left side one polish, right side second polish...
Fully removed here.
I didn't realise how rough the surface of your windows can get until i went over it with the diamond cut... when you first apply it, you see exactly where oxidation has taken place, as there are distinct outlines, you end up taking out rough surfaces which you didn't know where there in the first place. After this i'm going to do all the windows including the front windscreen. Did i mention it works great on your headlights and foggies too?
Edited by Howie
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
