If you are going to get a headunit that has an Ipod adaptor for it, I would recommend the alpine over the pioneer..
I have a pioneer 6750 in my car, great unit, but the interface for the ipod is clumsy.. you control it off the headunit - however you have to go through each albumn/playlist one by one - and there is no way to quickly scroll through them..
Great unit for what it is with my ipod just sitting in my glove box.. But just a bit clumsy..
REMEMBER - he must get an adaptor for the aerial socket to convert it from a japanese dual plug to australian single plug.. someone can tell you the part code - they are available from autobarn for about $20 - without it he won't be able to listen to the radio as the antenna won't be plugged in!!..
see here: http://www.skylinesaustralia.com/forums/in...showtopic=60275 for infor
Edited by Links
i hate sony headecks even if they have a slight power advantage THEY ARE SOOOOO UGLY!! sound aint bad but yuk!.
not a fan of alpine because just about every alpine unit looks the same plus my old alpine headunit didnt have a very long life despite its $800 price tag.
this is the bf here, someones been a naughty girl, goin behind my back to get me something, hope u read this as ur very easy to identify. i reckon the alpine if u were wondering and ill try and act surprised when u give it to me.
ps. dans got a good idea :dry:
ps. dans got a good idea :laugh:
rofl. hilarious. caught red handed!
ps. dans got a good idea :)
OMG...caught, so depressing :blink: I guess I should of make it less obvious that it was me lols...any way, from the comments of everyone, I guess now I have the get the system and all this time I thought if he was naughty I could give him some cheap arse present... :wave: , but since his gotten all you guy's backing, I guess I'll have to get him the system...and maybe a bj because I was a little bit naughty :P, if his lucky lols...
Thanks for all the headunit ideas :P and the others...lols
Edited by lovemoreful
Don't go ebay, support the local car audio industry plus any ebay company offering a warranty will be fixing it themselves, they won't be sending it off to a certified repairer.
Anyway, stick with Eclipse or Alpine and stay away from JBHIFI and Autobarn and stuff - go to a specialist store... at least they know what they are talking about.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
