Hey guys,
After a chat with a mate regarding tunes etc, just want to klnow what others have done!
Ok, so you have done the basic mods - exhaust, fmic and added a bit of boost with cold air/filter.
Now - have most of you guys left as is or decided to play it safe and go a tune to make sure all the AFR are right and such n such and making sure its not running rich or lean when boost comes on?
Because so far i have just done the basic mods as said earlier - and it got me thinking, am I going to destroy my motor later on by not tuning it for safety not just out right power?
Im not that smart with turbo motors and boost - my experience has been with LS1 motors!
or am I just being paranoid???
Cheers,
Chris
https://www.sau.com.au/forums/topic/129630-those-who-have-tunes-and-havent/
there are also things that you can do before you get a dyno done to help richen up the afrs (but results vary). first of all is to clean the afm. if its dirty then it isn't reading the correct amount of air and can make the car run lean. you can also check the fuel pressure. it is better to clean the afm before the dyno run, as you don't know if it will have any affect and then atleast you can see what they are like when its clean and if it is still lean thats 1 thing that you can cross off the list.
Hey Chris
Provided you don't do anything too silly, like run 30 psi or something, just the standard mild mods on stock turbo won'nt destroy your car, it just won't drive much better than stock, that's all.
On my car, i've done everything but the ecu, and i get big rich and retard. When that kicks in, it feels like I get pulled back. there's a big dip in power. so It doens't feel, nor is it actually very quick.
I reckon either do all the mods + tune, or just leave it stockish
nah im not that silly :thumbsup:
basiclly its on 7psi 90% of the time and then if i feel like it switch it to 11psi
Im just thinking now - perhaps I should get a tune to keep the motor safe - however buying a powerFC and tuning just for basic mods - is it worth it?
I dont know!!!
I dont know!!!
For the 2k you spend on the PFC and tune mate the car will run better and smoother, and thats with more power and being more fuel efficient too!! I'd say go for it, i plan to. :huh:
can you remap an r33 ecu?
i thought it was just r32s?
i'm not sure if anyone is australia does it. i have been told a place in brisbane does it. i have a remapped 33 ecu that was done in japan.
if you are only running at 7psi and occasionally 11psi then you could go the cheaper option of a safc2. it will make a noticable difference.
It won't really make it 'safer' because it's not really at much of a danger as it is. If anything, the benefit is in fuel economy and performance. It will make it have more power basiaclly all over the power range.
If you're going to do it though, i'd make sur ethat you do every mod you'd consider, so you don't waste money on a tune again later.
e.g. fmic, full exhaust, turbo if you want, camgears, etc.
Instead of an safc, take a look at the jaycar one. it is basically an safc in a cheap looking box at about 1/5 the price.
Chris, I know OF a guy that can remap r33 ecus. I have nothing to do with him, he just posts up on here occassionally. I'm actually saving up for a remap myself just to see how it goes. From memory, last time he posted, it was 350$.
the jaycar safc will be around $100. then the tune will be like $300. SAFC only allows adjustment of fuel, not ignition.
I reckon the remap for 350 is seriously a pretty good option. Fuel, ignition map changes. Removal of speed limit. you still retain all the good stock ecu stuff like cold start, consult etc.
Edited by 97r33gtst-typeM
thanks for the info mate!
Yeah I knowe the general rule of do all your mods - then get it tuned to suit. however I feel that this is all I want to do as now I want to get the suspension set up for some track/hillclimb work and eliminate that bodyroll! :P
cool - if you like could you pm me this guys name?
Wouldnt mind getting in contct with him!
cheers!!
Chris!
posted by toshi in an old post
in order to tune R33 on dyno, board is needed, which approximately costs $350-$400 only board.
Tuner makes ECU map on dyno themselves and this data is transfered onto PLCC chip then fitted onto the customers ECU
Other wise use R32 ECU ( need change all map.not only fuel and ignition).
R33 chip is selling at http://www.grid.co.jp/en/prod/prod93.htm.
This is a one time chip.
when remapping ignition timing DIY, make E F colum same as D colum ignition timing. ( also remove speed and boost limitter)
This means about same AFC.
And adjust base ignition timing by crank angle sensor about 2-3 degrees.
There is no need for a fuel map change.
Because when fitting dump pipe and hi flow cat , cat back, air pod , boost 0.8-0.9 bar A/F changes to about 11. (depends on parts performance)
A/F 11 is not rich. HKS kansai drag racer GTR A/F11 for safe and power.
I think rechip is cheaper way ecu tune for std turbo R33 GTS-T.(my map is totally different std map).
If change turbo in the future I recomend power fc for R33.
I think R32 do not need power fc.
If some one having pomping or fuel rich problem please send me PM or [email protected].
I be able to chack problem by softwear then I will fix it. ( NSW only)
http://users.tpg.com.au/yuna/Skylines.html
Basically a lot of mucking around and will be hard to find someone in your area to do it.
Edited by Munna1
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
