ok guys my prelude has to go
its a 1996 model, 5sp, vtir, engine and gear box were just changed with all paper work. Fully optioned, pod, Exhaust , has some damage on the driver side rear panel, very easy repair, or can be driven as is been quoted $500 for the repair really good for sum1 wanting a cheap, fast, low Fuel car. askin $6000 which is dirt cheap, call me on 0415838233 must be sold asap, located in sydney
now for the 300zx
ok guys this car is my pride and joy but i have to part with it.
Its a twin turbo 1993 model 5sp man (2 seater version) now for the work done:
ENGINE
#forged pistons
#twin core front mount (huge)
#aftermarket injectors
#aftermarket fuel pump
#shaved heads
#titanium retainers, stainless steel valves, valve springs,along with aftermarket cams
#Haltec v2 computer (thats a stand alone)
#boost controler
# single exhaust coupled at the front 4 inch from the turbos back opening to a 5inch cannon (this is a custom exhaust cost heaps and sounds amazing)
#twin hks ssq bov
#twin hks pods rerouted using stainless steel pipe and carbon fiber vents
#plus more
Gear Box
#strengthened 1st, 2nd
#brass but clutch (6 puck)
#lightened flywheel
#new seals
Rest of the Goodies i.e Looks
#adjustable suspension (not the cheap stuff)
#18" 9" dished rims chrome lip and black inside
#veilside body kit (frnt bar)
#carbon fiber frnt panel
#carbon fiber vented bonnet
#leather, electric seats
#Massive sound system including, DVD player, TV, amps, custom made box for the whole back of the car with a alpine 15in canon sub which is the best on the market, 6'9''s , tweeters, cones, and more
#turbo timer
#boost gauge
#pivot shift light
#momo leather wheel and pedles and knob
There is prbly heaps of stuff iv missed but trust me you will be amazed, the car has was a mid-night blue but is now under primer as i was planning a devil yellow respray ( think about it yellow with the rims and carbon fiber will look great) you can have it as is or sprayed in the color of ur choice or in the old coulor if u like, we can work some thing out. Normally peple will ask for about $20K or more for a car like this, but im realistic and want a fast sale so it will be set a $12000 depending on wat would be done with the paint which is the bargin of a life time and will prbly b sold 2 the first person to see it you can call me on 0415838233
Can you please tell me how many kms the Honda has and what sort of condition it is in?
Thanks,
Omar
now for the 300zx
ENGINE
#forged pistons
#shaved heads
#boost controler
#twin hks ssq bov
#plus more
Gear Box
#lightened flywheel
#new seals
#turbo timer
#boost gauge
#pivot shift light
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
