ok guys my prelude has to go
its a 1996 model, 5sp, vtir, engine and gear box were just changed with all paper work. Fully optioned, pod, Exhaust , has some damage on the driver side rear panel, very easy repair, or can be driven as is been quoted $500 for the repair really good for sum1 wanting a cheap, fast, low Fuel car. askin $6000 which is dirt cheap, call me on 0415838233 must be sold asap, located in sydney
now for the 300zx
ok guys this car is my pride and joy but i have to part with it.
Its a twin turbo 1993 model 5sp man (2 seater version) now for the work done:
ENGINE
#forged pistons
#twin core front mount (huge)
#aftermarket injectors
#aftermarket fuel pump
#shaved heads
#titanium retainers, stainless steel valves, valve springs,along with aftermarket cams
#Haltec v2 computer (thats a stand alone)
#boost controler
# single exhaust coupled at the front 4 inch from the turbos back opening to a 5inch cannon (this is a custom exhaust cost heaps and sounds amazing)
#twin hks ssq bov
#twin hks pods rerouted using stainless steel pipe and carbon fiber vents
#plus more
Gear Box
#strengthened 1st, 2nd
#brass but clutch (6 puck)
#lightened flywheel
#new seals
Rest of the Goodies i.e Looks
#adjustable suspension (not the cheap stuff)
#18" 9" dished rims chrome lip and black inside
#veilside body kit (frnt bar)
#carbon fiber frnt panel
#carbon fiber vented bonnet
#leather, electric seats
#Massive sound system including, DVD player, TV, amps, custom made box for the whole back of the car with a alpine 15in canon sub which is the best on the market, 6'9''s , tweeters, cones, and more
#turbo timer
#boost gauge
#pivot shift light
#momo leather wheel and pedles and knob
There is prbly heaps of stuff iv missed but trust me you will be amazed, the car has was a mid-night blue but is now under primer as i was planning a devil yellow respray ( think about it yellow with the rims and carbon fiber will look great) you can have it as is or sprayed in the color of ur choice or in the old coulor if u like, we can work some thing out. Normally peple will ask for about $20K or more for a car like this, but im realistic and want a fast sale so it will be set a $12000 depending on wat would be done with the paint which is the bargin of a life time and will prbly b sold 2 the first person to see it you can call me on 0415838233
Can you please tell me how many kms the Honda has and what sort of condition it is in?
Thanks,
Omar
now for the 300zx
ENGINE
#forged pistons
#shaved heads
#boost controler
#twin hks ssq bov
#plus more
Gear Box
#lightened flywheel
#new seals
#turbo timer
#boost gauge
#pivot shift light
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
