Good result mate peak power is very impressive, Id like to know what the go is with the torque spike to Dale. Boost starts at 2000 rpm 12psi by 3750 then slowly creeps to 13.7 at 4750 does this seem right for a GTRS people.
Edited by Munna1
Thanks mates! I'm extremely pleased with my results...
This matches my goals perfectly... I wanted something streetable that i could enjoy at track events occasionally...
As for the torque spike... i'm not sure... might have something to do with my tomei poncams?
This setup I'm running is in my 95 s14... i love it! Handles beautiful on the road... the GTRS spools rather quickly for the amount of power it can push... I was wanting something to enjoy on the streets and this turbo performs just as i had imagined it...
In stock form... boost would build and set you back... but then as you climbed higher into the 5-6000 rpms it seemed like it would start to drop off...
Now, it just wants to go... it feels like it would just keep pulling ... i bumped up my rev limit (using my pfc) from 6900 to 7000....
But in any case i'm more than pleased with the results... My tuner informed me if i wanted to go any further with power i'd need to upgrade injectors... he said they're getting border line to the limit (i'm using nismo 550cc)
Ok my tips and comments:
I think full boost is a little late for my liking. What boost level are you aiming for? I would increase the boost duty cycle to get a small spike at hopefully around 3600rpm that you can then flatten out later in the rev range.
What boost control are you using btw? If it's something that has different duty cycles able to be set depending on rpm like an AVC-R then increase it later where the boost drops off or drop it in the middle if you are only after 12psi.
Apart from that, does anyone here have any idea how this translates to rwkw on a dyno dynamics dyno?
If the hub dynos if anything read higher then the 550cc injectors you have should be well up to the task. Yes, looking at the a/f plot it is starting to head north at the top end which indicates lack of fuel.
But reading your list of mods, I would be looking to the walbro pump as a suspect before the injectors.
I had the PowerFC boost controller on there but the tuner could never get it to work properly...
The shop where this was tuned is an Apexi excel dealer and certified tuner... he was on the phone with Apexi telling them what was up and they couldn't even figure out why it wasn't working... he said maybe the solenoid was messed up...
So right now it's just got a bleed valve on there... Which i'm not exactly thrilled about... but it gets the job done
The injector duty cycle on the settings in the PFC are at 86.5%
Ahh I didn't see the mods cos they were in the sig. Yeah that walbro is running lean up top like they all do. Ditch it and get something better. A GTR pump should do the job.
I think the injectors should be up to the task too. Check the pump.
Unfortunately GTR pumps are a little hard to source here in the states... What do you think about a Supra TT pump instead?
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
