  • 1 month later...
  • Replies 66
Posted Images
Roy,
Clint who I haven't seen around for some time built up an rb25 with 26 internals nice cams and a GT30 .82.
The threads in the SA section of basic specs and the exact turbo.
He ran a high static comp thats one thing I do remember.
Mid 20's he made 580hp on an engine dyno and then once in the car with a slight tweak it ended up making 338rwkw or there abouts. I'll dig up the thread. Such a pitty the pics are gone as the thing looked awesome.
You may remember it. :D
http://www.skylinesaustralia.com/forums/in...c=61561&hl=
In the car he was running 1.5bar (so low 20's) and had cams. Again don't know what cams. :(
I do remember he was running a touch more boost on the engine dyno to make 580hp at the fly.
