I went to pull the dash off the R30 but I have no idea what do to. The manual shows how to remove the accessories from the dash but its all incorrect when being applied to my car. Like it shows 4 screws on the bottom of the glovebox holding it up but theres not 4 screws at all...?
Ive removed the stereo/heater/clock surround, the speedo surround, the bottom soft panels near the kickpanels, 2 screws on each side of the car holding the dash.
I dont know what else to do or where the screws are located. Anyone care to help if they know?
George,
It's a while since I pulled a dash out, but from memory, there is 2 screws at each end near the door jam, the bonnet realease lever is also holding it in or it's bracket is. The demister vents have to come out on top near the screen and I think you will find 3 or 4 screws inside them. Heater controls etc etc also have to be disconnected from their relevant units, speedo cable has to be disconnected.
Be ULTRA careful when pulling it out as there is a duct that feeds the top demister vents that tears/splits very easily and they're a bugger to find in good unbroken condition.
Try these and get back to me if you still have trouble and I will look at a spare dash I have under the house.
Cheers, D
George,
Cheers, D
Thanks!!!!! I have heater controls, stereo surround etc disconnected. How do I unplug the speedo unit?
George, Hi, Which Manual doyou have?
I have Publication No SM2E-OR30GO. If yours is different I'll look up in mine.
D is the brain, so go with him first.
Cheers, 66yo
It just has a clip on it, no more unscrewing like the old days, it has a nylon/plastic assembly on the end of the speedo cable.
Once you have the cluster free it is relatively easy to access.
Cheers, D
Ok Dash Is off.
It was a mission! I ended off taking the glovebox out so I could reach in and undo some plugs behind it. Then I did the air vent connecting cables. I found it an absolute mission to get the speedo cable out but i figured it out.
Had to lower the steering column first as I couldnt get the dash over the steering wheel.
I have the manual pedal box in now :-) There was a thing attached to the auto pedal box with a sticker saying "Chassis Control Box" what do I do with that?
I am NOT looking forward to getting the dash back on, the air vents look a mission to plug up....
Ok Dash Is off.
I'm not sure George, but I wouldn't have thought the dash would have to come out just to change pedal boxes.
I recently changed steering columns and brake booster assembly and left the dash where it was.
Also changed the instrument cluster to my Jenesis one and didn't experience the difficulties you described.
I'll check that box and get back to you.
Cheers,
Dennis
Theres 2 bolts that hold the pedal box on that are at the top right at the back of the dash on the firewall. maybe i did it the hardway but meh...its done. I just gotta it it back in
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
