Today im a proud owner of a r33 Skyline, went for my first fillup of BP ultimate and for some reason the car started leaking petrol during fillup from the nozzle hole! Now before anyone jumps to conclusions,
the tank was empty by the guage and i only put in 20ltrs cause its a thurs and fuel is $1.54!!!
Any ideas on why?
Edited by The Milf Guy
https://www.sau.com.au/forums/topic/129755-filling-up-skyline/
Hey all, new to the forum so first post.
Sorry to hijack a bit but didnt want to go creating a new thread. I also have just obtained an R33 and also just put in a tank of BP Ultimate. My question is, is the TERRIBLE fuel consumption im getting normal? I read on a link from these forums that it should get 9.8L per 100km. Well, I put in a full tank, set the tripmeter and it looks like ill get about 250km out of the tank (its nearly empty, filled it up tuesday)
Just wondering, Is that normal? I mean I know I shouldn't expect great ecconomy from a v6 Turbo but 250km's according to my math is 26L/100km Wtf?
ummm straight 6 turbo .
depending on your driving style and whether its city or country driving ..
std r33 gtst should see from 350-500 kms per tank..
o2 sensor on the exhaust would be main culprit other than thrashing the car
sorry straight 6. Used to saying v6 from my old car :P
newly complied ?
dodgy compliance change to the restricted unleaded nozzle hole on the filler pipe..
Yes just complied the other day, how does that affect the pump and make the fuel overflow?
and how do i check?
Thanks for the replies ppls btw
is your car stock, any engine work etc... if so maybe not tuned, but if its a stocka i think you might have a problem, try cleaning your injectors and the fuel tank might help a little
and how do i check?
Japan and australia use different nozzles, there for the hole must be changes...
am i right Craved..?
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
