Today im a proud owner of a r33 Skyline, went for my first fillup of BP ultimate and for some reason the car started leaking petrol during fillup from the nozzle hole! Now before anyone jumps to conclusions,
the tank was empty by the guage and i only put in 20ltrs cause its a thurs and fuel is $1.54!!!
Any ideas on why?
Edited by The Milf Guy
https://www.sau.com.au/forums/topic/129755-filling-up-skyline/
Hey all, new to the forum so first post.
Sorry to hijack a bit but didnt want to go creating a new thread. I also have just obtained an R33 and also just put in a tank of BP Ultimate. My question is, is the TERRIBLE fuel consumption im getting normal? I read on a link from these forums that it should get 9.8L per 100km. Well, I put in a full tank, set the tripmeter and it looks like ill get about 250km out of the tank (its nearly empty, filled it up tuesday)
Just wondering, Is that normal? I mean I know I shouldn't expect great ecconomy from a v6 Turbo but 250km's according to my math is 26L/100km Wtf?
ummm straight 6 turbo .
depending on your driving style and whether its city or country driving ..
std r33 gtst should see from 350-500 kms per tank..
o2 sensor on the exhaust would be main culprit other than thrashing the car
sorry straight 6. Used to saying v6 from my old car :P
newly complied ?
dodgy compliance change to the restricted unleaded nozzle hole on the filler pipe..
Yes just complied the other day, how does that affect the pump and make the fuel overflow?
and how do i check?
Thanks for the replies ppls btw
is your car stock, any engine work etc... if so maybe not tuned, but if its a stocka i think you might have a problem, try cleaning your injectors and the fuel tank might help a little
and how do i check?
Japan and australia use different nozzles, there for the hole must be changes...
am i right Craved..?
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
