**edit Eoi Sau Dynoday @ Boosworx 7th Oct
gtrGhosTDoGG11
 Share
  • Replies 422
Posted Images
My coils have decided to go kaput.
Hopefully I get them in time, previous parts I order from nengun took 1month. :S
If I need to step aside due to reaching the target I have no problems doing so. If so I will still be there. :)
Sorry guys, gonna have to pull out, I just went to pay and remembered that my 21st is on the same day. Got preparation and stuff like that in the morning to get ready for the big night. I'll definitely be keen for the next one though
If I need to step aside due to reaching the target I have no problems doing so. If so I will still be there. :rolleyes:
If you need some to tide you over you're welcome to use my spares.
You've got my number so feel free to give me a buzz.
Thanks to Madaz and Lee for the deposits.
Who is Stuart ? Whats your SAU nick?
A quick update.
3. gtrGhosTDoGG11 paid
8. Nightcrawler paid
16. Madaz paid
23. Lee paid
Only 5 people have paid a deposit. Could you please leave a deposit asap.
Edited by gtrGhosTDoGG11
Sure can! :) PM me with the details
cheers mate :PBJ:
A quick update.
16. Madaz paid
23. Lee paid
Hi Will (?),
I'm fairly sure I PM'd you a few day ago with... 'count me in' - maybe it didn't make it? I'll be there on the day and I daresay my car will still be at the workshop. If the car is ready then I'll put it on the dyno.
If you like (and don't mind?) I can pay Shaun tomorrow when I'm at the workshop.
Cheers,
Matt
Hi Will (?),
Cheers,
Matt
Hi Matt,
Soz, must of missed that pm. I'd rather you dont pay him as it might cause some confusion on the day and cause extra hassle for him. I'll add you on the list and pm u with deposit details so you can do it online.
thirtyfour - ive added you on da list, and pm'd u
Can i grab a pm of the details please, i think it's about time that i paid the deposit :D Now that i read the thread correctly and realised its in September! lol
Edited by DC_GTST
 Share
    • Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts.
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
