  • Replies 422
Posted Images
Did this day get rescheduled or not? Did someone check with Shuan & Troy to see if they had intended on watching the Grand Final or has a TV been organised? My car may still be there needing to be pushed around as I wait (assuming I've bought them by then) for new turbos to be delivered/installed.
Oh dear, no idea too. Also depends if the locals are in it. Hrm.... who else wants to change the date, I can organise a TV there oh and hide the beer. LoL
I can start changing plans tomorrow if people want it done.
Cheers.
make it a week earlier? need to know asap for date change as i gota get that sat off from work n latley they been pricks.
i rekon most ppl will wana watch it so 2 avoid ppl not showing up will b good idea to change it
Just spoke with Troy and Shaun and neither really care about AFL so not fussed. Shaun didn't seem too concerned if the final caused numbers to be slightly reduced either. He said they might put a TV up for those with some interest.
bleh - you can't watch a grand final standing around chatting to people, with a noisy car at wot in the background .... Madaz - imagine the most exciting sporting (or indeed arts or whatever) event of your choice, and that is what the Grand Final is to most South Aussies :) .... I know guys who have missed weddings due to watching the Grand Final.
Either way I am having a Grand Final event at my place on the big screen, so I can't make it. I am sure a lot of other people are pre-booked too .... in fact with any sort of luck the Crows are in it, in which case I'll be in Melbourne ;)
Pretty keen to come down and see everyone again - and perhaps put the R on the dyno, however I won't know whether I can make it or not until the day. Work has me on standby so pretty unpredictable right now. Alright to pay on the day?
If you get called in you'll be going faster and making more power than any of us, so I guess that's some consolation.
I like the new date, I'm still in.
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
