**edit Eoi Sau Dynoday @ Boosworx 7th Oct
gtrGhosTDoGG11
 Share
  • Replies 422
Posted Images
If you get called in you'll be going faster and making more power than any of us, so I guess that's some consolation.
Good point well presented - something about 18,400 hp that still makes me smile.......now if we can only strap it on the dyno........
Id b interested in bringin my S15 if thats ok. I havent seen alot of the older members for a long time, and would b good to meet new members
Let me know pls :P
haven't seen u on the forum for a LONG time!
I tell u what, like i said, even in stock form this car is so much fun. I cant wait once its modded.
Good luck sellin yours, ive seen it advertised, and its definately a bargin for the amount of money you have spent on it, and how well its been looked after.
Lookin forward to catchin up with u lot soon
Turned to the dark side Enrico? Nice :huh: Enjoy the S15! Nice car!
My website is old because I sold the car. So I pulled the link to it. Got another S14 now with a bit more work done to it hehe. Catchya at the dyno day if I am able to make it!
busky, i hear u have a t518z? 10cm aswell? Thats what im lookin at
i have a HKS2540 (shaft play) sitting on my cupboard
bought it for my s15 but never get the fund to rebuild it (your choice of 25-30/35/40)
and the car is now gone :P
send me a PM if u are interest
Edited by Maxx
 Share
    • Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts.
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
