**edit Eoi Sau Dynoday @ Boosworx 7th Oct
gtrGhosTDoGG11
 Share
  • Replies 422
Posted Images
Was a good day. Good to put a few names to faces. :mad:
The lowest power reading for the day was when everyone left.
Little $500 1.8ltr gemini owned by Darren, 38rwkw, a little ign timing and got it up over 40rwkw ripped the aircleaner off and up to ~45rwkw. :)
Great job by Will & g/f it was well organised :whistling:.
Was definately a top day & decent turn out. Was also, good to meet some of you.
I'll try loading up some footage early this wk but, in the meantime Im sure someone has photos.
Edited by pkblade
Thanks Will for organising the day so well, couldn't have gone any smoother.
I'm personally very pleased with my own result too :ninja:, sorry to see a few others that were dissapointed by theirs.
It did show up the need for a front mount on my car too since it dropped 7KW on the second run, & that they didn't indicate I had any fuel delivery issues was good to know too.
$25 well spent IMO
Edited by JazzaR33
Yeh cheers Will, thanks for the oganisation mate, was fantastic....... So were those snags mate, I think you've cooked a few in your time.
Was good catching up with some of you guys, Top day, cars, beer, good company and wickid weather, couldn't have asked for more. And especially when i decided to run my car and was amazed it got what it did, grin from ear to ear!!!!!
Sam where the hell were you mate?????
Thanks to Shaun and Troy gettin fumed out, was a great day cheers!
i couldnt make it mate, i promised to do some work on a friends car the same day and it coincided with the dyno day. sounded like a really good day! what number did you run Darren?
All good mate! Yeh i got 230.1kw, think i might have a boost leak or something, cos i only got the 212kw just under a year ago at Boosworx when Shaun put in my Z32, FP and FC retune, and i have touched it since! Meh i'm not complaining!
wow thats awesome! you would be stoked with that. 230 is what im aiming for, i just gotta save for that hi-flow!
Sam, Im saving up to get the highflow that Slide performance is offering. Its pretty much exactly the same that Darren has.
hey Duc, Shaun gave me a really good price for a hiflow from ATS + fitment and tune, which suits me good because the FC will need to be adjusted afterwards :D
 Share
    • Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts.
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
