Im 4wd... would they drop my front transfer shaft?
meh. pity, Id like to have a funrun but Im not going to pull the shaft myself; guess Im stuck with the 4wd dyno boys.
sounds like fun tho.
  • Replies 422
Posted Images
damn broken suspension.... i would love to have come and bring some old flava to the mix but im out of action... sorry guys, might come down and watch but
yeah ill be in and i imagine Lee will be in also
most of us are 4wd it take roungly 5 mins to take out the front shaft out u will also have to take out the 4wd fuse
from memory he wouldnt take shaft out as there is to many of us and would become a hasel
im sure sum1 could help you if your not confident to do it yourself
A warm up run then a run in in shoot out mode.
I wont be running my car, dont have a Nissan anymore, do I know you DCGTST?
ummmm.....not that i know of. Ive been on a few cruises, and know a few people from boostworx
Depending on numbers I guess, would you be open to having a 'shared day' with some calais turbo people? We were thinking of having one around then as well at boostworx. These aren't your typical boongers ripping skidz down hindley street haha.
http://calaisturbo.com.au/showthread.php?t=83052
Can i add at a dyno day Shaun had a small while ago for another car club (not mentioning names *cough* silvia *cough*) some knob decided to do a burnout in front of his workshop to celebrate his power figure....
One of the nearby residents called the police, and they came and shut down the dyno day.
If anyone does any similar behaviour be prepared to have all other members of sau sa looking down at you....
I'll be in....to watch :)
I don't think the dickhead was celebrating, more like having a sook as it read 50rwkw less than the dyno happy dyno he tuned it on the night before:)
Apparently it has blown up now..what a pity
cheers
darren
Darren,
What dyno did he run on the night before to read 50rwkw more????
From what ive seen, Shauns dyno seems to be fairly accurate.
I personally wouldn't mind a few calais turbo ppls, always widens some of the skyline ppls eyes with how much potential the old RB30ET has and power made with simple mods... :)
If these guys (VL's) are going then I either want to be the very first or very last when no-one is watching lol. Seeming they put out an average (when modded) of anywhere between 200-500 rwkw (i know they can do more if made to do so :)). This is if i'm able to make it due to footy finals -> Be same weekend. So I'm 50/50 to be in. I can pay the deposit if need be, but can't guarantee I'll be there :s
I should get some tyre spikes and wait down the street incase anyone decide to leave marks!
Edited by DC_GTST
nah I reckon having too wide variety of cars ruins it .... would be far better if we just restricted it to Skylines with the odd Silvia thrown in. Just my 2c.
Will, I have Paypal'd you the $10.
I don't mind a few VL's rocking up as they did last time. After all they are an RB 6cyl Turbo. :)
The only thing I would suggest is maybe no NA VL's or even NA silvia's etc.
Its even good having the odd LS1 on there, spices up the day and gets people interested again. Have the same lightly modded 32/33/silvia after 32/33/silvia and it tends to get a little boaring.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
