  • Replies 43
Most of the bad threads to do with Prestige and J-spec have all been deleted. Mainly because J-spec sponsors SAU (not sure if Prestige does). That said J-spec are reasonably good though. See your in Perth.. PM sent
mmmmm, generally people who have had bad experiences have no one to blame but themselves hey :woot::)
I love misinformation :) I have never deleted threads on SAU because of sponsorship/financial status.
Anything posted on SAU is the responsibility of the owner (Prank) who has created the SAU Guidelines and made it clear that he doesn't tolerate negative comments directed towards businesses.
what makes you say that?
Well with the importing process/purchasing of your new car, both with j-spec and prestige...they make it very clear that they are only in the business of aiding you in chosing the right car for yourself. Auction Grading, mechanical inspections and high resolution pictures are at your disposal to help you make this choice. What i am saying is, at the end of the day, YOU are the one that choses the car. Therefore if anything goes wrong mechanically or anything else thereafter it really isnt anyones fault but your own.
thanks.
Edited by Sambo33gtst
Why not buy a car thats already here? You get a chance to inspect it yourself, take it for a test run, and get a workshop to inspect it too.....
Because someone has to import it at some point in time, provided you do the homework like Sambo said, it's generally going to be okay. I still think it's competitive cost-wise to import over buying an already-imported car.
You took the words right out of my mouth :rolleyes:
Generally if you import yourself, and i did say generally, you can save anywhere between $1,000-$5,000 compared to if you bought privately here in Australia (Typically R33's). Just got to be patient and find the right one for the right price :)
  • 1 month later...
  • 4 weeks later...
J-spec dont really ask prices for anything mate. they offer a service to find and help you import cars from japan. they simply ask their fee ($1000 AUD from memory) to find the car (either at dealers or auctions) and buy it on your behalf and help you import and comply it. so what the car costs is up to you.
and in my sig :mellow:
I think we did have a couple of 180sx's for 15k landed n complied... mind you they were 1996 models which hadn't been drifted/thrashed to an inch of their life and hence ineligible to be imported under SEVS (the only way you can import a 180sx these days).
I'd easily recommend J-spec. Although I'd recommend that if you want to buy, have all your finace organised first. I'm sure they get the 'I'll call back once I've got the loan" all the time.
Yeah the sales guys do get that from time to time, but we've given quotes and in some instances spoken to the bank etc where they need something solid to approve the loan. Some banks are hesitant to give loans to purchase cars that aren't in the country for some reason :laugh:
and in my sig :laugh:
Why is it that a car that hasnt been drifted/thrashed ineligible to be imported under SEVS? Am I reading this wrong? I thought 180's are eligible under SEVS
No I meant that most non accident damaged 180sx (ie eligible for SEVS) haven't been drifted or thrashed. Depending on the compliancer and engineer involved, even something like a repaired rear fender could fail compliance.
lol i should have put a comma in there to break it up.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
