Purchasing from J-spec
Looking at a car with them. would be nice if some of you coul PM me with your experiences. were they on time, did theyre estimate end up being close to final price. any other tid bits. thanks.
  • Replies 43
Most of the bad threads to do with Prestige and J-spec have all been deleted. Mainly because J-spec sponsors SAU (not sure if Prestige does). That said J-spec are reasonably good though. See your in Perth.. PM sent
mmmmm, generally people who have had bad experiences have no one to blame but themselves hey :woot::)
I love misinformation :) I have never deleted threads on SAU because of sponsorship/financial status.
Anything posted on SAU is the responsibility of the owner (Prank) who has created the SAU Guidelines and made it clear that he doesn't tolerate negative comments directed towards businesses.
what makes you say that?
Well with the importing process/purchasing of your new car, both with j-spec and prestige...they make it very clear that they are only in the business of aiding you in chosing the right car for yourself. Auction Grading, mechanical inspections and high resolution pictures are at your disposal to help you make this choice. What i am saying is, at the end of the day, YOU are the one that choses the car. Therefore if anything goes wrong mechanically or anything else thereafter it really isnt anyones fault but your own.
thanks.
Edited by Sambo33gtst
Why not buy a car thats already here? You get a chance to inspect it yourself, take it for a test run, and get a workshop to inspect it too.....
Because someone has to import it at some point in time, provided you do the homework like Sambo said, it's generally going to be okay. I still think it's competitive cost-wise to import over buying an already-imported car.
You took the words right out of my mouth :rolleyes:
Generally if you import yourself, and i did say generally, you can save anywhere between $1,000-$5,000 compared to if you bought privately here in Australia (Typically R33's). Just got to be patient and find the right one for the right price :)
Hi I just to ask Has anyone buy a car form J _spec import?Are they hard to deal with and are they can trust in price when they bring in in Australia are they charge more than price that in advertising Thanks a lot :P
  • 1 month later...
  • 4 weeks later...
J-spec dont really ask prices for anything mate. they offer a service to find and help you import cars from japan. they simply ask their fee ($1000 AUD from memory) to find the car (either at dealers or auctions) and buy it on your behalf and help you import and comply it. so what the car costs is up to you.
and in my sig :mellow:
I think we did have a couple of 180sx's for 15k landed n complied... mind you they were 1996 models which hadn't been drifted/thrashed to an inch of their life and hence ineligible to be imported under SEVS (the only way you can import a 180sx these days).
I'd easily recommend J-spec. Although I'd recommend that if you want to buy, have all your finace organised first. I'm sure they get the 'I'll call back once I've got the loan" all the time.
Yeah the sales guys do get that from time to time, but we've given quotes and in some instances spoken to the bank etc where they need something solid to approve the loan. Some banks are hesitant to give loans to purchase cars that aren't in the country for some reason :laugh:
and in my sig :laugh:
Why is it that a car that hasnt been drifted/thrashed ineligible to be imported under SEVS? Am I reading this wrong? I thought 180's are eligible under SEVS
No I meant that most non accident damaged 180sx (ie eligible for SEVS) haven't been drifted or thrashed. Depending on the compliancer and engineer involved, even something like a repaired rear fender could fail compliance.
lol i should have put a comma in there to break it up.
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
