Thats good news, thought we might get squeezed out.
Should get there early to grab a carport.
Paul see if you can get boosted zed to come out to play. :)
i would say not much chance of a carport unfortunately. might be able to get one for the morning but in the arvo guys will be wanting to move in to their alloted bay (i know we will!).
good news paul on the session structure. should make for a fun day then :woot:
  • Replies 77
looks like my shift at work is changing and fridays are my saturdays...
SO....could be a goer for me!! :(
and now that my brother decided to have his bucks party on the fatz grip n drift day - this day looks much better for me.
many spots left?
heheheh
Paul - not sure if you eremeber mer - but few years back I dud an SAU track day in my LS1 - signed up on the skylines downunder - was over 3 years ago- so you guys have gotta be nice to me as ill be back to beginer skill !!
I think I do remember, that was a while a go. Everyone has to be a beginner at some stage, its nothing to worry about, its more important that you just get out and have some fun, and not do it on the steets.
Im in the R32 GTS-T doing some development and practice, its my first full track day in this car so I dont expect to be doing V8 times or anything like that either.
Nice one!
Cheers Paul - cant wait to get back out there!
whats the expected turnout of cars? Is it similar to the motoconcept days where theres group a, b and c?
OK,
They run 3 groups. 20min of each hour
C3/4 Cars (Normal race car licence group)
Bikes (National race bikes)
L2S (Us!)
So we basically go out in 1 group, normally there will be a few super sprint guys and a few others + us. I think last time there was about 15 cars, some fast and some slow but not much to worry about.
In order of priority of what to do.
Bleed brakes with Dot 5 or 6 I use the Motul 600V, UAS have it for $50 a litre.
Check pads if they are crap pads make sure you have at least 50% wear, if you have good ones ie Frodo 2500's make sure thay are no lower then 25%. Stopping is number 1!
Tyres make sure you have about 40 PSI, you can always take air out but is a little harder to put it in, dont come out with sh!t tyres, they dont grip well and you often undone, ask yogi.
Change your oil if its older then 5000km, and get a service as well if you have not had one in a while.
If you have suspension mods 3-4 Deg of camber is a good thing on the track and caster is nice as well, so a wheel alignment is cool if you want to be hard core.
Thats about it unless its your first time your car has seen the track, and it has a few mods. It may need pay to get a retune, ie street or drag tune cars dont always last 8 x 20min at full noise.
I think thats it, see you out there.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
