why would you wash the filter when you can buy a new one for under $40?? :)
the M35 ones look a lot simpler, C34 filters are fancier and enclosed in a plastic bracket, hence the hefty price of $170 for the pair. My paper is starting to look a little ragged after a few washes, might have a go at swapping some new filter paper/cloth into the brackets.
Could be a chance the M35 ones are a standard Nissan size, RCA113P (30 X 219 X 200), that are used on other models. eg a MAXIMA/PATROL/PULSAR/X trail etc ...
can someone confirm the size.
http://www.rycofilters.com.au/catalogue/pr...ma/part/RCA113P
http://www.advancedauto.com.au/pics/Cabin%...%20location.pdf
Ok, so is there any sort of trick for the series 2 to get the 2 filters out. I have removed the glovebox, metal and plastic panels behind and I am left with the bottom filter being stuck behind a panel that is attached to the dash and can't be removed without removing the dash or cutting. The top filter seems to be stuck. I can pull it out about 5mm but it won't come out any more. I figure if I can remove the top filter then I should be able to lift the bottom filter up and pull it out. Is this the right idea? Does the top filter just need a bit of gentle persuasion? This is a pic of what I am faced with..
I have a metal cross brace that sits in front of that plastic one. I think I might just cut the plastic one with the trusty Dremel since it doesn't look to serve any purpose. The metal one reinforces that area so, I guess it's time to start cutting..
Ive searched many Japanese sites, only a few options for aftermarket filters for C34, plenty for M35.
This guy did the same as ST, cut the bracket.
http://minkara.carview.co.jp/userid/127545...90838/note.aspx
I ended up cutting mine as well. I don't think mine have ever been replaced. Will have to invest in new ones due to the fact that even with soaking mine, they are still very blocked up.
Just had a quick look on FAST - when you bring up the part number for the filters it has the one that Chook mentioned in the first post (B7274-0V525) and it also has (27275-0V510) which matches the number on the end of both my filters. It say's that there is 2 per vehicle for the second number (0V510) but only 1 for the (0V525). I will order using the part on the end of my filter and see how I go with prices.
Edited by SSStagea
Im also going to try to get some, prob from japan.
From that Jap guys DIY, looks like you get these ones, AY684-NS003, http://page18.auctions.yahoo.co.jp/jp/auction/w26837896 (R33 ones) and trim the end down, in the spot where they look like they are meant to be cut.
Once again Chook is right, they are a multi fit filter for about 20 different models and they need to be cut as per the pic. Last time I bought one, cost me the equivalant to $50, problem is, at todays exchange rate one would set you back about $83(!)
the 0V510 is a superseeded filter, not made anymore, Nissan will give you price for the 0V525.
wtF is that plastic brace doing there??? I have a 2000 model series 2 and my brace is metal, and removable (screwed in with 2 screws either side). Looks identical. I'd cut that brace out all together at each end.
hahahaha! classic :D
Yeah unfortunately filters for C34 are paper and in my case did not respond well to being soaked to clean; after 10 minutes with a toothbrush trying to get the tar out (mine were 'smokers filters') I gave up and ordered a new one of jap auctions. They fit and work fine, and look original. But white :blink:
Yeah, I have the metal bracket to but when you remove it you are greeted by the plastic bar. I cut it and got access to the filters. Will make it easy now for replacing in the future.
Thanks for the info Chook, will price them tomorrow.
Okay folks, Nissan Australia have provided me with the part number B727C-79925 this is for an R50 Pathfinder A/C pollen filter kit (2 pieces). I have physically checked it against the filter I took from my Series II and it is practically the same. They want $53.85 for the kit (2 filters) with no trade or SAU discount.
I could confuse matters by saying another dealership in the same city just 17km from the first, gave me this number MK270C-79925, didn't recognise the other part number above, didn't have any in stock and couldn't give me a price, so I won't. Most expect this from Nissan Australia.
Also, there a two types of filter available in Japan: Pollen & Smell filters (4,700 Yen) & Pollen only filters (2,100 Yen) By the looks of the one I saw at Nissan it is the latter.
What were the differences you saw between the 2 ? I have ordered this one, http://item.rakuten.co.jp/ap-murase/pc205b/ , (pic is not relevant) but in the table at the bottom it is for an R50 pathfinder as you said, but there is note next to WC34, basically saying that it is not an exact fit. So I am assuming it will require a modification.
There is also a possibility that the N15 Pulsar ones are a close match, but im not sure if the Oz model had them fitted.
Will post pics once I receive them.
Timmeh, not sure where you are in NSW, but you should have gone into Lincorp (Parramatta Nissan are part of this group) and shown your membership card for SAU-NSW - they would probably have given you a discount equivalent to the trade price or similar. I think there is also some account number you have to quote to get the SAU-NSW discount as well as show your card, but details would be in the NSW Members' section.
Ive got a series 1 '97 and have had the Glove box out like 4 times looking for these suckers and have had no luck at all :'( And i think my car was a X smokers car but not sure :S
Will take some photos of under their tomorrow and people can give me a bit of a hand..
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
