Hi All.
It's a bit urgent. I once stumbled upon a generic intercooler install on the site somewhere; I think it was in PDF format, showing how to install an intercooler on an R33. AND now I can't find it.
Can someone please help, if they have one post it up or PM me? PLEASE.
Hi guys, has anyone got a version of the instalation manual scanned or a coppy they can send me through, i recived my kit form CRD wich is absolutly fantastic, i will post pics.
Only thing, no instructions, i know it's a generic type but i need to see where to cut the hole.
Can somone give me some hints as to where the whole needs to go for the piping and cooler.
URGENT.
Here you go.
Got it off the Hybrid site but can't find it now.
Can't remember is it was hybrid of HDI or some other name they go under.
Good luck.
I've posted some pics up somewhere to if you wanna check em out.
In the Forced Induction i think
Intercooler_Installation_GTSt.pdf
thanks mate, found them LATE last night, exactly what i was after.
Quick question, the piping has no nipple for the wastgate actuator,did you guys make one up. Also i think the bracket for the main top pipe is out on mine, can somone post a pic of their engine bay for me. Ta
No nipple on mine either. Just extend the hose and T-Piece it into your vacuum hose off your blow off valve. What kit have you got?
yeah i have the CRD kit which is same as HYBRID. The thing is it is not good to have the wastgat see vacume, hence why the bleed is usually taken before the butterfly, i would fix it, as sooner or later it will stuff up.
I simply drilled and tapped my main cast pipe and scrwed in a nipple connection for the hose, no probs so far.
Can you elaborate on this a bit for me? Reasons why?
The wastegate is sprung to hold the gate shut until it sees a pressure form the boost controller, or thereabouts, and putting the gate under vacuum can damage the membrane inside as it was not designed to see vacuum.
Also the gate will open slower if plumed off after the throttle, this is because the controller never sees full boost as quick and allow for the gate to work.
Basically it, it is easy to do, go to a auto shop ask for a 5mm vacuum nipple with a treaded end, mine was 8mm thread hole, and drill and tap, use some silicon tape and hay presto.
PM me if you need some help
man the hydrid kit look like a bit of stuffing around..
is there a kit that doesn't require cutting holes because i think it is now illegal to cut any part of the frame.
isn't there a kit that connect up to the two stock holes?
yess there is an ARC side mounted one, that replaces the stock unit, or you can get a R34 GTT side one if you are only going to have 200kW or so. But ARC also do a front mount that uses stock piping, do a search and something should come up.
VERY pricy though, R44 GTT much cheaper.
Pretty sure any FMIC install will have to take a bit out of the reinforcement bar. Give it a shot. I did mine and I had never used an angle grinder before.
I did this over the weekend and boost is coming on a bit quicker now. I just thought i weas experiencing extra turbo lag when I intsalled the FMIC but it looks like the turbo takes a bit longer to boost up when the connection is made after (?) the throttle
Cheers Wog.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
