just wondering how much power rb20/25 afm's will support on a R32 gtr? I see most people use the z32 afm's but they are quite alot more expensive. Was reading an old zoom mag and they said to use the rb20/25 afm's. Im aiming for about 300 - 320awk. Will thse do the job? Also do the wires for the plugs need to be changed around or are they straight plug in?
Cheers
https://www.sau.com.au/forums/topic/129803-rb26-with-rb2025-afms/
plugs are the same but the flex hose will fit if you try really hards LOL. you will need a re map thought as i did this to find it was very lean on the air fuel ratio.
Cheers mate. looking at that then 2 rb20/25 is plenty for what im after. You know if the plug or wirring needs to be modified to fit to a rb26?
Interesting people have not steered ytou on the straight line!!!
You'll be able to get away without changing the AFM's
Ferni did using GT-SS i believe, and im also gonna give it a whirl on my very similar setup :P
Munna's "rule of thumb" is totally wrong in its power readings.
Z32's/Q45's read a fark load more than 250/300rwkw respectively
Although its more about airflow than power anyway
well maybe i should keep the cash and go for the tune straight away with the standard afm's. im running hks 2530's pfc and have a set of sard 700cc injectors to through in. Think i should invest in a pump then instead of afm's.
Is it possible to put an external 044 inline with the standard pump without using a surge tank?
Hi, I have R32 GTR with standard afm's and 375 kw at the rears on 18psi. Havent tried to push them any further yet though. Hope this helps. :thumbsup:
Do you have a Power FC?
What is the max voltage you see, as i regularly see 5.1volts with 310hp(230kw?) at the wheels.
Anyone else maxing there AFM at similar power level?
So you say you standard 26 afm's a maxing out at only 230rwk? something cant be right there. They both read that?
Hi, yes I do have power FC. Im not sure about the volts, I dont realy play with my FC, But Ill try to find out for you next time I drive it.
Yeah mate I know, I"ve read the tables too,with 400hp atw apparently the limit on std AFM(or Scoop may prove us wrong)
But they both read roughly the same,using the sw check they seem to fluctuate within a few millivolts of each other.
Could also be due to the cold weather as I never noticed them sitting that high in the summer.
It would be interesting to see other peoples power and peak voltage..
Hi guy's, first up Im not a tuner and I dont claim to know much about tuning. Im trying to learn but its all beond me, give me a chev with a holly carb and I can tinker with that just fine. Anyway my AFM are maxed out [no tuneing resolution] but they still flow the air to support the power. That is the way it has been explained to me, and that is all I can go on. What power would I need to run 10.9 @ 127.4 mph? Fair bit of wheelspin through first gear. This was my first time out with the car as we'll. :(
Hi guy's, first up Im not a tuner and I dont claim to know much about tuning. Im trying to learn but its all beond me, give me a chev with a holly carb and I can tinker with that just fine. Anyway my AFM are maxed out [no tuneing resolution] but they still flow the air to support the power. That is the way it has been explained to me, and that is all I can go on. What power would I need to run 10.9 @ 127.4 mph? Fair bit of wheelspin through first gear. This was my first time out with the car as we'll. :D
You ran a 10.9? or your asking how much power you would need? What turbos are you running?
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
