Got my car dyno'ed today... its been a long time due, and with the issues i had at the recent G1 comp (ignition cutting out) i took with me spares of everything, AFM, CAS, Ignitor etc to swap it over.. but it turns out that the ECU is a bit on the dodgy side
I always thought i had a stock map on my ECU.. but turns out that its been remapped in Japan, whoever did it, certainly likes their taste for fuel, as throughout the whole midrange (4000 - 6000) rpm the fuel mixes were off the scale and mega rich (off the scale being lower then 10:1) Couldnt believe it and neither could jeff... so he went to work taking out all the fuel, adding some timing and so forth. Took a few runs and due to some weird as ECU related issues, we wasted a lot of time and chips and so we were cut short on the dyno time.
My main goal was to increase the midrange torque and so forth, i wasnt really fussed about the top end power as much, as i was happy with that and i didnt want to run anymore boost then i already was. So with the changes to the map we were able to get phernominal torque out of the RB20 around the 4500 rpm range, the KKR430 comes on HARD now and basically the torque curve in 3rd gear is near verticle, in 4th it is equally massive. several times the car tried to climb out the dyno... crazy!
Final figure was 197.4 rwkw's on 1 bar boost, Runs were done in 4th gear.
I have taken pics of the dyno graph, however Jeff is going to be changing this in the very near future to smooth out those midrange mixtures some more.
All in all im very happy with the results.. On the road it basically translates to massive wheel spin when i floor it in 3rd and even more wheelspin when i grab 4th :)
Big thanks to Jeff from The Speed Lab for persisting through all the related ECU and chip drama's and Steve from jazmac for helping out and the Dyno hire.
Power run showing AF mixes in 4th gear
Pink is 3rd gear and Red is 4th gear... Keep in mind that power and torque figures are accurate in 4th gear...
https://www.sau.com.au/forums/topic/129817-dyno-run-with-kkr430-turbo/
Do you want an honest opinion or a pat on the back?
PM me if you want the honest opinion off the forum.
Pat on the back follows;
Looks like a good value for money result.
:D cheers :stupid:
Edited by Sydneykid
From thier own website
KKR-430
Intended for 2.0–2.5L engines, this turbo features a T3-size exhaust flange. This makes it an ideal upgrade turbo for RB20DET and RB25DET engines*. Rated at 430hp, it is suitable for drift and street performance applications, where minimal lag is preferred. It uses a 2.75in V-band flange for the exhaust outlet (V-band and flange included).
Tested on an RB25DET at Panther Aftermarket, it produced 230kW at the wheels with only 11.5psi of boost. The standard internal wastegate is designed to hold 11–12psi.
230rwkw/11psi/rb25 - doubt it
:D cheers :stupid:
thats just it, people feel the need to make opinions because its a cheap turbo and bush bearing, but at the end of the day it makes power and it costs bugger all doing it.
wheelspin in 4th with 197rwkw?? Do you have granite tyres?? :D
I was thinking the same thing. I spin in 3rd when planting my 400rwhp datto with 195s and stupid camber......but with 350rwhp I hardly ever did...not to mention the 280rwhp you have. No offence but whats the go?
Get those af ratios to 12 and youll be making more poke.
Well done but do as above and enjoy more power.
wheelspin is provoked by torque delivery being so sudden rather then peak power figure. and yeah the tyres on the back were a bit average, 235/45/17's however poor quality rubber.
I think that's because it's accelarating from a low speed. If he was at say 4000rpm in 2nd gear even throttle then planted it, the boost would come on quickly after a second or so whereas with a bb turbo it would be more gradual resulting in less wheelspin.
That's how it looks to me anyway. I have driven a car the same as mine with a KKR turbo and that's what it feels like.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
