Got my car dyno'ed today... its been a long time due, and with the issues i had at the recent G1 comp (ignition cutting out) i took with me spares of everything, AFM, CAS, Ignitor etc to swap it over.. but it turns out that the ECU is a bit on the dodgy side
I always thought i had a stock map on my ECU.. but turns out that its been remapped in Japan, whoever did it, certainly likes their taste for fuel, as throughout the whole midrange (4000 - 6000) rpm the fuel mixes were off the scale and mega rich (off the scale being lower then 10:1) Couldnt believe it and neither could jeff... so he went to work taking out all the fuel, adding some timing and so forth. Took a few runs and due to some weird as ECU related issues, we wasted a lot of time and chips and so we were cut short on the dyno time.
My main goal was to increase the midrange torque and so forth, i wasnt really fussed about the top end power as much, as i was happy with that and i didnt want to run anymore boost then i already was. So with the changes to the map we were able to get phernominal torque out of the RB20 around the 4500 rpm range, the KKR430 comes on HARD now and basically the torque curve in 3rd gear is near verticle, in 4th it is equally massive. several times the car tried to climb out the dyno... crazy!
Final figure was 197.4 rwkw's on 1 bar boost, Runs were done in 4th gear.
I have taken pics of the dyno graph, however Jeff is going to be changing this in the very near future to smooth out those midrange mixtures some more.
All in all im very happy with the results.. On the road it basically translates to massive wheel spin when i floor it in 3rd and even more wheelspin when i grab 4th :)
Big thanks to Jeff from The Speed Lab for persisting through all the related ECU and chip drama's and Steve from jazmac for helping out and the Dyno hire.
Power run showing AF mixes in 4th gear
Pink is 3rd gear and Red is 4th gear... Keep in mind that power and torque figures are accurate in 4th gear...
https://www.sau.com.au/forums/topic/129817-dyno-run-with-kkr430-turbo/
Do you want an honest opinion or a pat on the back?
PM me if you want the honest opinion off the forum.
Pat on the back follows;
Looks like a good value for money result.
:D cheers :stupid:
Edited by Sydneykid
From thier own website
KKR-430
Intended for 2.0–2.5L engines, this turbo features a T3-size exhaust flange. This makes it an ideal upgrade turbo for RB20DET and RB25DET engines*. Rated at 430hp, it is suitable for drift and street performance applications, where minimal lag is preferred. It uses a 2.75in V-band flange for the exhaust outlet (V-band and flange included).
Tested on an RB25DET at Panther Aftermarket, it produced 230kW at the wheels with only 11.5psi of boost. The standard internal wastegate is designed to hold 11–12psi.
230rwkw/11psi/rb25 - doubt it
:D cheers :stupid:
thats just it, people feel the need to make opinions because its a cheap turbo and bush bearing, but at the end of the day it makes power and it costs bugger all doing it.
wheelspin in 4th with 197rwkw?? Do you have granite tyres?? :D
I was thinking the same thing. I spin in 3rd when planting my 400rwhp datto with 195s and stupid camber......but with 350rwhp I hardly ever did...not to mention the 280rwhp you have. No offence but whats the go?
Get those af ratios to 12 and youll be making more poke.
Well done but do as above and enjoy more power.
wheelspin is provoked by torque delivery being so sudden rather then peak power figure. and yeah the tyres on the back were a bit average, 235/45/17's however poor quality rubber.
I think that's because it's accelarating from a low speed. If he was at say 4000rpm in 2nd gear even throttle then planted it, the boost would come on quickly after a second or so whereas with a bb turbo it would be more gradual resulting in less wheelspin.
That's how it looks to me anyway. I have driven a car the same as mine with a KKR turbo and that's what it feels like.
    • Nah, new members can't post pics until they reach a certain post count. If I get a chance I'll promote you to full member, if @Prank or someone else doesn't get there first.
    • Drilled the rubber out on a slow speed and it didn't catch much at all. Probably only half a dozen holes was enough to shred the rubber and it dropped off easily leaving the inner sleeve behind. Will tackle that later
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
