Genuine Kakimoto Racing 17inch Deep Dish Alloys
Genuine kakimoto racing 17inch deep dish alloys. very rare kakimoto rims i have not seen another import or aus deliverd car with these rims on. selling because i want to go bigger and fatter.
Fronts are 17 x 8.5 with 9inch rubber, rears are 17 x 8.5 with 10inch rubber's. will suit any skyline from R32 to R34 (multi stud pattern) front rubber is brand new rears have roughly 65% tread. will sell with spacers.
I'v only got pictures of the rims on the car. slight gutter damadge but can be fixed (i was quoted $50 a wheel thats repair and polish)
Asking $2300 Negotiable (this is less than what i paid for them WITHOUT RUBBER)
not sure if your aware, but theres another set on here for sale for $1200 inc brand new tyres (allblitz)....bolt straight on to skylines (no spacers required). there 17x8 an 17x9 with black centres.
good luck with your sale, but not to sure many people will pay such a high price for 17's. Do you have any photo's, will usually help your sale.
Didnt know that but see how i go im not in a hurry if they dont sell im not to worried. iv got spacers on the front of mine cause of the offset, tried takeing them off but the wheel hit the brake caliper. ill try to get some photos up for anyone thats interested. thanks for the feedback though.
cant get the photos up but there the Same rims guys but mine arnt black there a grey colour
Edited by anton33
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
