Hi everyone,
I was just having a look to find the best spot to fit the catch can ... i jus dunno, has anyone here fitted one and also ive searched for how to fit and noticed there seems to be 101 ways to fit them .. is there a good simple legal way to fit them ?
Any pics would be awesome!!
Cheers
Lee :(
https://www.sau.com.au/forums/topic/129876-oil-catch-can/
k i found an article on the "correct " way to fit a oil catch can in HPI.
Find the that hose that goes from the cam cover to the inlet pipe just before the turbo. The catch can and hose replace this hose (Cam cover hose to catch can, catch can hose to inlet pipe)..... sounds very simple can anyone confirm this is correct as ive seen so many different setups ..is there any difference in setups apart from venting to the atmosphere?
And still trying to find a good spot to locate it ...surely someone else has one?
Also bout the reason for one ..RICE!! hahaha nah JK i was advised to get one. I had a bit of oil seaping thu after i turned the boost up. As ive just upgraded the turbo and will be looking at higher boost levels it seems like a good cheap safe option.
And as mentioned, the real reason isnt so much for what you see on the outside of the engine but on the inside .. An oil catch can removes oil, moisture and blow-by gas that causes carbon and sludge build up in the intake system and engine to keep them clean.
So i think for under a $100 its a great investment.
If i find the perfect spot, ill post up some pics ...if anyone has already found it pls post pics too
Cheers
Lee :P
https://www.sau.com.au/forums/topic/129876-oil-catch-can/#findComment-2403518
i would be asking sk, but i dont think the setup is quite as simple as how you have stated.
I dont mean to be rude, but there is a bit more to it than that, i did fit one to my old car without doing any blocking of the pipes by running hose here there and every where but in the end i took it off as it was more of a pain than anything.
Sorry to be sounding negative and i hope i am wrong as i would like to fit one myself, but from my understanding it wasnt quite as simple as that.
Simon
https://www.sau.com.au/forums/topic/129876-oil-catch-can/#findComment-2406123
cheers mate,
nah thats not rude id prefer to find out now rather than after ive done it ... i got the info from HPI after a guy wrote in and asked the correct way to fit an oil catch can to a R33 skyline. HPI are not the bible tho so any good advice and experience are more than welcome..
surely cant be too hard tho i got 1x can 1xhose and some fitting screws and stuff ahahaa almost shameful to ask what to do with it hahaha :no:
https://www.sau.com.au/forums/topic/129876-oil-catch-can/#findComment-2406171
Oh ok no worries then, when i installed on my last car i used a thread that i found on this site, i fitted to an rb20 so i assume it cant be too much different.
I hooked mine up the right way but probably not the best way, and im definately not saying that there is only one right way.
Edited by FLYSLY
https://www.sau.com.au/forums/topic/129876-oil-catch-can/#findComment-2406194
mines in the only spot i could find and i dont know whether rb25 engine bays have room here but its a good little spot. its next to battery and fuse box, i got the catch can made from a local shop to my dimensions and looks a treat and fits perfect. im not sure if rocker cover breathers come out in suitable spots for that location. i put a drain from catch can back into the sump on mine but u need a fitting welded onto sump to do it, or make a tee peice into your dipstick tube for the return hose. its not vital but saves having to empty it ever, though a good engine shouldnt pump oil through except maybe a fine mist when on fullboost.
as u can see i had to slide my battery over towards the drivers side gaurd abit but its still mounted using factory battery clamp and all so its not hard to do.
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/129876-oil-catch-can/#findComment-2421245
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
