well one plug is obviously the cyclinder thats causing the problem
To begin, stop using iridi's. They are a pointless waste of money.
as 3lit said - BCPR6ES-11's.
Get a set and put them in and then see how that goes.
Then it will most likely kill the plug again, but thats the problem, the bung plug which looks a tad oily
Ok so i disconnected each coil to narrow it down to a cylinder that was the problem, its no.1.
First thing i did was pull the sparkplug out, looks a bit black, and has that shiney coat i mentioned earlier? Could be fuel??? but had no strong fuel smell to it...
Ran a compression test - 150psi on that cylinder (didn't have time to do the others)
Put in a copper plug, didn't fix it, took out the splitfire coil and replaced it with my standard one, didn't fix it.
So at this stage i'm assuming it has to be a wiring fault to the no.1 coil.
Ok so thought i was stupid to do the compression on only 1 cyl so went back and did the whole thing
No1 150psi
No2 150psi
No3 140psi
No4 140psi
No5 145psi
No6 140psi
no 1 actually gave a reading as high as 160psi but with a couple of repeats the figure was 150psi.
you disconnected the coil and the idle changed?
If so, its the coil, or a connection to it which might be corroded
Get a spare coil, and test it. If the idle is fine then new pack time.
I had a similar problem to this with my R33. Mis-fired all over the place. Trackside performance found that, when they opened up the loom, half the wiring was corroded! looked like water damage.
When they replaced it, she ran smoother than it ever did before.
So give your wiring loom a check just to make sure its in good nick.
After all, these cars aren't exactly spring chickens remember. A lot of them sit in the USS auction yards for years, outside in the rain and sun. Its gotta take its toll on something sooner or later.
Yeah was suspecting the loom but the fault was traced to the injector - although there was power going to it, the ecu triggers the injector to inject by earthing it - which it wasn't doing- pulled out the ecu to check for faulty parts, water damage etc- all good- put it back in the car ran fine again! I suspect a loose connection either in the pin of no.1 injector earth lead (on the ecu side) or a problem within the ecu itself- maybe dry solder joint?
Either way problem was fixed and only cost $88 (took it to an auto electrician in the end) !! (i was thinking hundreds at least!!)
  • 4 weeks later...
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
