well one plug is obviously the cyclinder thats causing the problem
To begin, stop using iridi's. They are a pointless waste of money.
as 3lit said - BCPR6ES-11's.
Get a set and put them in and then see how that goes.
Then it will most likely kill the plug again, but thats the problem, the bung plug which looks a tad oily
Ok so i disconnected each coil to narrow it down to a cylinder that was the problem, its no.1.
First thing i did was pull the sparkplug out, looks a bit black, and has that shiney coat i mentioned earlier? Could be fuel??? but had no strong fuel smell to it...
Ran a compression test - 150psi on that cylinder (didn't have time to do the others)
Put in a copper plug, didn't fix it, took out the splitfire coil and replaced it with my standard one, didn't fix it.
So at this stage i'm assuming it has to be a wiring fault to the no.1 coil.
Ok so thought i was stupid to do the compression on only 1 cyl so went back and did the whole thing
No1 150psi
No2 150psi
No3 140psi
No4 140psi
No5 145psi
No6 140psi
no 1 actually gave a reading as high as 160psi but with a couple of repeats the figure was 150psi.
you disconnected the coil and the idle changed?
If so, its the coil, or a connection to it which might be corroded
Get a spare coil, and test it. If the idle is fine then new pack time.
I had a similar problem to this with my R33. Mis-fired all over the place. Trackside performance found that, when they opened up the loom, half the wiring was corroded! looked like water damage.
When they replaced it, she ran smoother than it ever did before.
So give your wiring loom a check just to make sure its in good nick.
After all, these cars aren't exactly spring chickens remember. A lot of them sit in the USS auction yards for years, outside in the rain and sun. Its gotta take its toll on something sooner or later.
Yeah was suspecting the loom but the fault was traced to the injector - although there was power going to it, the ecu triggers the injector to inject by earthing it - which it wasn't doing- pulled out the ecu to check for faulty parts, water damage etc- all good- put it back in the car ran fine again! I suspect a loose connection either in the pin of no.1 injector earth lead (on the ecu side) or a problem within the ecu itself- maybe dry solder joint?
Either way problem was fixed and only cost $88 (took it to an auto electrician in the end) !! (i was thinking hundreds at least!!)
  • 4 weeks later...
    • Welcome!  We're not all grumpy.
    • Welcome. We're all grumpy old men (and a few grumpy old women) who are slowly coming to hate these cars. Any of the newer owners who have joined in the last few years are rapidly catching up with us as they realise they have bought a basket case and that parts are getting difficult to find. Just be realistic about your goals. You'll need a fat stack of cash to buy an R34 GTR, and you'd be far better off using that to buy absolutely anything else (ie, shares, a house, scratchy tickets) unless that fat stack of cash is only ~10% of the actual fat stack of cash that you have. You'll never want to drive an R34 GTR on the street if you have fear of it getting destroyed. That's more or less true of the 33s and 32s also. Most of the RWD cars have been drifted backwards into power poles. No-one knows what they are worth these days because they are not changing hands. My car has notionally been down to <$10k value at some point and was probably sellable for $40-$50k in the height of COVID stupidity, but I have no idea what it's really worth now. It's irreplaceable anyway, because... where would I find one to replace it? Being realistic means either paying a lot of cash for a really really clean example that you will only drive on sunny Sundays, or buying one to daily that you will not want to be really really clean, for the same fears of destruction that applies to the GTR. I daily mine and some people think I'm crazy. But....to me it's just a car that I bought last century with the express purpose of driving it as my daily. The silliness that has happened since doesn't affect my original purpose. I have well and truly amortised the initial purchase cost and most (probably all) of the subsequent modification costs. But I don't think I could go out and buy one now to daily.
    • This is insane! The M1 likely to be closed for the entire day!  https://www.abc.net.au/news/2025-05-02/m1-motorway-delays-as-metal-shards-cause-flat-tyres-/105242272
    • Hey everyone! I'm quite young and I don't have enough to get a car right now but I love Nissan Skylines (Specifically the r34 GT-R. I'm so original I know.) and I would love to buy one in the future. I have no background knowledge, only an interest in cars, but I'd love to learn how they work so I can mod in the future. I've done some basic research on what model of Skyline I would start with and what mods to get started with are but nothing else. I'm here to learn! Hope you all have a great day
