R32 front cut
Engine and gearbox gone
Brake booster $30
R32 instrument cluster 106k manual $100
R33 GTST Series 2 Full set of seats $500
R33 GTST Series 2 Rear arm rests side pods $100
R33 GTST Door sill guards (they have Skyline printed on them) $50
R33 GTST Standard suspension with King Low Springs rear only $150
R33 GTST Tail lights white $300 for both
R33 GTST Series 2 Dash Cluster manual 88000kays $150
2 R33 GTR 3 guage Din $80 each
White bootlid with R33 series 2 spoiler. $200
R33 Catback exhaust 3" no restrictions mild steel with cannon 4.5" $450
Gold Coast
Will deliver
https://www.sau.com.au/forums/topic/129890-r32-half-cut-and-r33-parts/
  • Replies 74
is there any chance of getting a slightly clearer pic of the HKS exhaust temp gauge as im very interested but cant even read the face of it.
thanks pm pic if you want to.
Rb20 and GTR Pete :huh:
Sorry forgot to add that in origional post lol
Jst wondering if that oil cooler has gone and if it is for a or 33 =)
I have not heard anything from the origional buyer so if im not contacted it will go to 2nd in line it is a very popular cooler :)
do you mind if i ask what the F-com will do? fuel or ignition or both? and how old are they? if they are for rb20 than im gessing around that age?
has the exhaust gauge sold yet?
and also wondering if the hks ssq bov sound the same as the new ones?
Edited by DJRIFT
Pm's replied
Jason it doesnt include the temp sensor and ill get back to you with better pics when i get back from Sydney on Tuesday.
ES86 It doesnt include any loom however they can be bought over the counter at Jaycar. :D
Damo The Fcons are completely programable fuel computers that run inconjunction with the standard computer.
The Exhaust guage is still available and the SQ BOV does sound different to the SSQ
It is not as direct and high pitch as the SSQ is.
Sorry about the late updates i am in Sydney at the moment and will be back on Tuesday night.
is the FCON suitable for the rb25det? does it come with all the neccessary wiring harness?
Only RB20 and RB26 sorry.
hey bud, i am after a bov for my stock r33 gtst. what have you got? can you show me pics? i am in sydney...
These 2nd hand blow off valves are the only ones i have and apart from the one with the pipe kit will require a flange to be made. :)
Aaron I will take the wheels. PM your banking details please. And also oil cooler for r33?? Is it sold?
PM Sent
ill take the hks bov thats not attached to the piping give ya 55 posted.let me knwo via pm and ill transfer you across soem cash.
Done, you have pm.
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
