  • Replies 74
White R33 doors and mirrors complete available also now
small dint in passenger side near bottom corner near the hinge
White bootlid with R33 series 2 spoiler.
still got:
R33 GTST Series 2 Dash surround including aircon vents (missing power arial switch) $150
(also need then ones that go in the door, and just behide the front winscreen for the aircon)
will u ship to perth?
Guest
