ebay will have everything but the wing.
or autobarn for the LED lights and possibly the eye lids, and possibly the mirrors.
for the wing try some panel beaters.
Edited by mad082
Just recieved my R34 COUPE and wanting to fit AERO MIRRORS, REAR WING pics below EYELIDS and LED REAR LIGHTS.
Any information on where to get these would be great, businesses or Forum members.
Post up here or pm is fine.
I'm located in Brisbane.
Cheers
DMD? ur in queensland so try them for that stuff, maybe not the LED lights htough i dunno
The led tail-lights look damn cool but are a serious waste of money IMO. I think they're extremely expensive but maybe they were just the set i saw. Can't remember where i saw it.
BTW what set of wheels are in that pic??
The Nismo genuine tail lights are close to $1000 landed. The aftermarket copies are horrible and have not matched the pattern of the nismo lights and look poor as a result.
As for the eyelids, you can buy genuine ones from Nissan. The part number F2410-AA007 FIN-HEADLAMP SET (part number varies per color, that is for black).
As for aero mirrors, the only ones you want to get are Ganador's. Theyre a direct bolt on available in all standard Nissan colors as well as carbon fibre finish and retain all electrical functions. For those the best prices are Yahoo Auctions or Nengun - See www.slidewizeimports.com to help you buy it or www.nengun.com for Nenguns website.
Wow i didn't even know they had genuine ones. Got a picture of them? Also a price for them?
Edited by Howie
Very few people took that option.
Here is a pic of the factory eyelids on a R34:
http://www.sewid.org/gallery/d/2296-4/photo55.jpg
Price is - unknown
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
