Whos going to be in Brisbane for the Easter weekend?
It seems a few people are coming down from Rocky/Gladstone and Prank is coming up from the Northern Beaches..
I know theres already a thread about an easter cruise, but I think something should be set in concrete.
Wheres our fearless leader. *hollers for slip*
Just wanting to see who would be interested in having a cruise sometime during the Easter long weekend and where too.
Please post your availability/opinions for where to crusie to.
Maybe we could do that Hinze Dam/Advance town crusie from around midday one day and have a bbq??
Any other suggestions??
Just for the people who are too lazy to scroll through the whole thread :D
Final cruise details are as follows
6:30pm meet at crazy clarks carpark springwood
7pm leave and head south
now id suggest everyone has a full tank of petrol and has a feed before departing springwood cause i dont think we would need to stop at the service centers, probably cruise down the m1 in the left lane at a lesurly pace (read speed limit)(yes thats right mick ill be keepin well away from ya )
and then we arrive at bwcp and park in a group, 8pm, and then we all get to know each other....
https://www.sau.com.au/forums/topic/12990-easter-weekend/
  • Replies 164
well theres always a mad mt run, tambo run to hinze was good (just ask slip :D)
sounds like a good thing tho, ill hit the refidex and see what i can see in the way of decent cruise paths, somewhere else we could go is currumbin rock pools, or little nerang dam up in springbrook is a very nice spot, and i know a way we can go that will sate slip of yearning to drive through the mountains
https://www.sau.com.au/forums/topic/12990-easter-weekend/#findComment-245212
one mild problem for anyone out of town is the dawn run though ... for instance if we were to leave from bris/coast anywhere i and a few others would ahve to leave 1 1/2 hours or so earlier which would be annoying... sleep ins are good on holidays........but i would probably be in for a cruise and meet some locals indeed.......
https://www.sau.com.au/forums/topic/12990-easter-weekend/#findComment-247044
If we wanna all cruise down to the BWCP we are going to have to leave early.. Like 7:30ish and head down the coast... We got there at 9:00 the other night and it was just starting to fill up so I reckon if we leave here no later than 8:00 on the saturday night we should be able to park together or at least in a close proximaty of each other and talk down there.
https://www.sau.com.au/forums/topic/12990-easter-weekend/#findComment-249638
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
