bar is a measurement of pressure, just like psi.
Just enjoy your car for a while. Leave the turbo side of things alone for now. You have an R34 dude seriously! I'd swap my 180 for it in an instant! There is more to life than boost...
  • Replies 164
OI...Back on topic here.
Course you can park with us squizz :P you can park right beside me!
What if we do get down to the Gold Coast around 8ish. I'll probably be coming home early that night because of the dyno day the next day. So maybe starting earlier is a better idea. We can have dinner at yatala pies before hand!
This is boostcruising's dyno day.... Hang on I'm getting confused.
Let me work out the dates. We are thinking of having this cruise on the easter weekend yeah? So thats the 18th - 21st April. The saturday night is the 19th April. That's the night were looking at right?
The dyno day is.... *drum roll* oops sorry. May bad. It's not till the next weekend (the 26th April)...
So No.. I wont have to come home early*YAY*
So. The night we are looking at is the 19th April. Its a Saturday. Will everyone thats coming to brisbane be here for the drive?
Ok. heres a general idea of what we could do. i havent really put times in other than the time we should be at bwcp, this is because the carpark tends to fill up pretty quickly after 8pm, by 9 its pretty full usually and by 11 well its nigh impossible. so here we go....
saturday night cruise to bwcp
brisbane people meet at springwood in the crazy clarks carpark which is just up the road from the springwood maccas (brisbane people should know where im talkin about)
leave there at a pre determined time and head down to yatala to stop at the pie shop for some dinner, of course those who need fuel can pop on over to the bp and fill up, (and MRE can get some nandos chicken :P)
leave yatala pies and head down to the broadwater carpark to be there around 8pm so we are all parked in a bay close to the entry so people can look at our cars in all their glory :P
ok, goldcoasters some of you may not want to head to yatala to meet up with the group, so if yas need a staging point beforehand let me know and ill come up with something, otherwise the main point is to be at the bwcp by 8pm so we are all together and parked near each other, that way those who havent met each other before can have a chance to meet each other.
any ideas put em foward, lets try to make this happen as best we can so no one misses out :P
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
