Hi guys
I have a set of 4 wheels, NISMO LMGT4's in Bronze colour for sale.
They are off my S14 as I now have 17's on there for street use.
SIze is 18 x 9.5 for hte rear and 18 x 8.5 for the front.
not sure about hte offset, they were off an R33 skyline originally I was told. and fit my S14 perfectly. so would probably suit most skylines.
One front left rim has some minor rash on it. (damn driveway) other then that the rest are in good condition.
asking price is $2400. willing to neg if you are serious. but serious offers please. I was told these in this size would be around 1100 per wheel new or something like that (NISMO, what do you expect)
Now these wheels are awesome, they arelighter then std 16" R32 GTR wheels. you can lift them easily with one hand including tyre on it. HOWEVER you will need new tyres on them as they are shagged at the moment. why I have the price really low.
please contact me via mobile as I rarely have time with work to be on forums these days :)
0411113875
pics available via email if you sms me or call. or I can arrange inspection
cheers
mark
https://www.sau.com.au/forums/topic/129940-fs-nismo-lmgt4s/
Just spent over $1100 on new tyres for my 17's!!! If not i would have bought these too!!! well if ur interested in trade for Black centre/chrome dish 2 piece Kakimoto NG-T in 17 x 8 and 17 x9 (same as the ones Allblitz is selling on this forum) with new Falken FK-452 + cash adjustment please let me know:)
Cheers
Jason
Edited by JaseR33
https://www.sau.com.au/forums/topic/129940-fs-nismo-lmgt4s/#findComment-2404264
if you read the first post, as per that, TYRES ARE SHAGGED! big time
2 fronts are camber worn to death (not my car, like that when I got them)
2 rears are the same but have screws in the tyres aswell. not worth repairing.
but come on for this price guys, the rims are 1100 EACH I am told without tyres brand new. this is like less then half the price!!
mark
https://www.sau.com.au/forums/topic/129940-fs-nismo-lmgt4s/#findComment-2437999
  • 3 years later...
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
