Hi all! i bought my 1996 Series 2 Skyline GTST bout 5 months ago and i wanna take it for a service... I live in Sydney Nrth beachs area and i wanna know how much u all pay for a full service..
Im gonna get my Oil changed
oil filter
fuel filter
brakes checked
wheel alignment
wheel balancing
spark plugs etc etc and i got quoted $250.00???
IS that a normal price? what sort of cost am i looking at?
any advie would be great!
https://www.sau.com.au/forums/topic/12996-servicing-r33-series-2/
Guest RedLineGTR
Oil changed ->
You can do yourself (Pick Your Own Brand)
oil filter ->
Easy do when draining oil (Filter easy to get Ryco 145A)
fuel filter ->
Do Yourself (Ryco Z200 Or Z201 Or Gen Nissan)
brakes checked ->
Pop One of ya wheels off check how much pads are left. (recommend system flush and new fluid along with new pads)
wheel alignment & wheel balancing ->
Check the tires pop one or two off check tread if being worn wrong,or steering wheel shakes, if none of those it should be okay.
spark plugs ->
Takes abit longer than the others, but well worth the effort, some preformace gains on decent plugs compaired to old ones that have been in there since new.
Most of these topics would of been covered, try searching for them, or if stuck about any of the above i'm sure someone would help out.
Cheers Rob
Yea i hear where u coming from Rob, but even though its all easy, it just takes a decent amount of time, so i might as well get it all professionally looked at and done...... i used to do the service on my VL myself, but with my skyline i wanna take a bit more care and plus the mechanis doing it owns a R32 and knows the good oils to use..
what oil would u use on a modded 1996 series 2 GTST?
my mechanis suggest semi synthetic.... what do u suggest for a car that hasnt done too many k's??
Guest RedLineGTR
Everyone uses their own brand or whatever price sound decent, but 99.9% chanage their oil at 5000K or less, buying pricey oils at $100 most people cant afford the constant forking out of 100 buck on brand like Redline(full syth). I Use Shell Helix Ultra 5-40W i rekon would prob go for 10-40w seems good not to thin not ot thick semi syn or full syn your choice.
In the End, go with what the mechanic uses, if he believes it good then it should be okay, have a look around the forums and web sites of different brands and comments. Also long as you dont buy the home brand type of oil..lolz
In most cases you get what you pay for depends on ya budget how far ya wanna go. Mobile 1, Shell, Castrol, Motul ,Penrite
Hey MRK!! im in Frenchs Forest! so sorta nrth beachs area..
I have gone on a couple of cruises with the ENVY boys from MANLY? u know them?
i dont see many series 2 skylines round here, but i reckon it would be good to get a crew to cruise.... wat u think?
im 22 m n i work in Brookvale..
The mechanic im gonna take it to is in Forestville and the details r
SAFETY SERVICE CENTRE
1 CURRIE ROAD
FORESTVILLE 2087
PH: 9451 4761
OR 9452 4909
Give em a call and ask to talk to Harry n say Phil with the Black Series 2 skyline said to give you guys a call for a service on skyline...
This Harry guy is a top bloke n he has a Skyline of his own, he knows all the ins and outs and has a passion for skylines... so i fully trust him!!
Like everybody says, it is worth doing it yourself if you want to spend the time and save money (or spend the money on the rest of the car, etc).
Some people have the perception that the skyline is some sort of magic car - but servicing a skyline is pretty much exactly the same as any other car on the road. Why get robbed on the prices for both the parts and then pay the labour costs ontop? Spend the money on the tuning.
Ok, well i think much of this has been covered before in other threads. But a bit of an idea of prices:
Fuel Filter - $15 Ryco Z200 (same as for VL basically)
Oil Filter - $12 Ryco Z145A
Oil - depends - $35 - $60 will get you a range of decent ones
Spark Plugs - NGK BP6RES coppers - $25 for a set of six (repco)
So your basic service = $87 plus whatever u value your time at :(
The mobil fully synth or semi-synth work pretty well too. Last change I used Mobil Synth S 10W-40.. $35 I think it was from Kmart :D
Kamikazze.. spark plugs aren't too difficult but it does take a bit of work (maybe 30 mins) to get to the actual plugs. I'd post a tutorial but i don't have a digi cam so makes it a bit difficult.
Fuel filter is pretty unclamp and replace.. main prob is just getting the sucker off, as it sits pretty tight in the fuel line. i got a bit of fuel everywhere but eventually i got it all hooked up
err...yes.. that scibyline guide for the oil was good
http://www.skylinesaustralia.com/forums/sh...&threadid=10035
Somebody should mod that up to a sticky i think! In fact we need lots more stickys so the same questions don't keep getting asked.
I got a full 5L in although most say you can only put 4? anyway :D
mac, take a chill pill, I don't see any replies here that are not trying to help you out. Also please try to post your questions in they're respective sections. I've gone over this question for you in NSW and I wil do it here for good measure ...
As I've mentioned, I take my car to Mark @ Hills Motorsports (02) 8802 0777.
Here's a few things to give you an idea of pricing, obviously each individual service would be different however this should give you an idea of cost.
Labour at Hills is about $80 p/hour ... All of this will most likely be around 7.8 Hours of work, so around $624 in labour.
All these prices are off my latest invoice, they are ex GST ...
Fuel Filter - $16.36
Oil Filter - $16.36
NGK Spark Plugs - $3.5617 each (six required)
P/S Belt - $30.51
A/C Belt - $ 28.09
Alt Belt - $14.50
Timing Belt - $89.82
Thermostat - $42.57
Water Pump - $139.18
Castor Rod (pair) - $86.36
Brake Fluid - $18.18 p/litre (2.2l required) Motul Fluids Used
Clutch Fluid - $6.32 p/litre (1.1l required) Motul Fluids Used
P/S Fluid - $30.908 p/litre (2l required)
Engine Oil - $14.57 p/litre (5l required) Royal Puple Fluids Used
Gearbox Oil - $25.69 p/litre (6l required) Royal Puple Fluids Used
Coolant + Flush - $30.908 p/litre (2.5l required)
gordo do i actually have to take the plenum off? cos ive taken all the intake pipes off b4 when i was trying to take the cam covers off, but i couldnt get to the left one cos the intake was right above one of the bolts i was trying to get at... so i thought i may have to take the plenum off
same wif the spark plugs?
nope.. you have to take the main air piping to the plenum off though.. thena couple of side hoses.. then u take that plastic cover off thats says "nissan 2500". The coils and plugs are under there.
i think you're thinking the way i was thinking before i worked it all out - its not near the injectors like other cars.
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
    • Came here to say, put all the wiring from the new motor and gearbox in that you can, then throw the stock ECUs in the bin, and get an aftermarket ECU. Should be pretty easy if you can use a multimeter and read a wiring diagram to then use a PNP aftermarket ECU to suit the motors wiring loom, and make the minimal changes you will to get it to work in with the body loom (If any). This will mean you can very easily circumvent/bypass the Park/Neutral start disable switch, and get everything running really easy!
    • If the roof is dual skinned the whole way, IE, there's a "top" metal piece, and a "bottom" metal piece, to slow it down as much as you practically can, you should be able to get an attachment for a spray can/your spray gun, where it is a long, thin flexible hose, and when you're "spraying" it is spraying it in every direction possible. The I'd get that, and feed it through the roof as much and as far as you can. It's basically like fish oiling the car, but you're soaking it in rust converter. Then do the fix like Murray has described having cleaned up the existing metal as much as you humanly can. I'd also throw as much rust converter on that exposed metal before putting the fibreglass/metal filler over everything.   As for welding a replacement in. I've owned my own MIG welder for about 10 years. I've also worked in an industry doing MIG welding for a job for about 3 months dead straight, and we were doing 11.5 hour work days 5 days a week, plus a Saturday 6 hour day. (I then moved over to running the massive CNC plasma as I could understand the technology, and work with the main guy out there). I also f**k around with my welders a bit at home. So what I'm saying here is, I've probably got more hours on a MIG gun than you'll manage to get under your sleeve doing home sorts of jobs over the next 5 years. I also have an ACDC TIG that I got myself a year or two back. I've got a short amount of experience on the TIG only. My home MIG is also presently setup for doing thin sheet metal. Unless I didn't care about how that roof looked, and I just wanted a functional metal roof, and it being out of alignment, warped, and bowed, I would NOT attempt a roof replacement UNLESS I could do it as a whole panel like Murray described where the spot welds were.  Welding has this REALLY annoying thing, where if you want something to be perfectly square, unless you can clamp that thing to damn perfection (Welding fixture table), it is NOT going to be square, so you start to learn, the type of metal you're working with, how thick it is etc, and weld in VERY specific ways, and by knowing how YOU are as a welder, so that as the welds cool, the metal work pulls itself into place. If you want to see some cool tricky shit done, Bennets Customs is an Aussie guy, and he mentions a guy a lot call "Kyle", who is from "Make It Kustom". Watch some of their welding videos, especially on sheet metal. You can use the welder to shrink the steel in, and you can also use the welder to stretch the panel out. When you have the skill level that I have, you can shrink the metal in and out... But never on purpose like those two guys do. You just manage to f**k it all up. Then I smack it around with a hammer till it sits lower than I will want it too, then I shove filler on top and then pray to deitys that I can sand it into some form of sane shape that doesn't look like a dog has taken a shit, after eating a tonne of pumice stone... I'm all for DIY, and for learning, and please, feel free to give it a go, but be aware, you need to live with the consequences of how time consuming it is to do, AND that it's going to look no where near as good as what you can make it look with just some filler now. Oh AND, even once you replace it, it's like to still rust away again eventually, because you'll have missed putting primer and paint on some part of the newly welded in sheet metal, or against part of the existing metal you couldn't get to...   Oh, and to weld all that in, you will need to pull the window out, and strip at least the roof and A Pillars of interior trim and wiring. You'll then need things like the big fire proof/weld spatter proof mats to lay down, OR you'll end up needing to strip the ENTIRE interior to avoid sending it all up in a ball of flames. If you want to see how annoying sheet metal is to weld, head to bunnings, buy there 600x600 1.6mm mild steel (Not GAL!) sheet, and cut a few pieces, and try and weld them together. Then understand, 1.6mm sheet is nearly 50 to 100% THICKER than the cars sheet metal.   The photos I posted before, I'm replacing with 1.2mm thick mild sheet, and it's very easy to blow through both the original steel (Especially if I hit an area that should have probably been cut out a bit more) or straight through the new sheet metal. And I'm doing the floor, which can be hidden easily, and doesn't matter how pretty I make it, as long as it's damn strong! I'm also doing it in a 4WD, that has seen many off road trails, and doesn't need to look that pretty ever
    • This sounds like a perfect excuse to install a Haltech R3.
