Got to thinking the other day - I wonder if you would do a purpose built , road registered , track day car for like under $8,000 total - ready to race.
Must be quick enough to have fun in - must handle well and brake well. Also must be fairly economical on consumables and repairs (if required)
So I put my thinking cap on and came up with this.
Suzuki swift GTI - you can get them for about $4,000 - $5,000
Rip out everything you don't need - make it as light as possible.
Upgrade shocks and springs - get allignment, camber and castor done especially for track work - say $1500
Chuck away standard rims and tyres - Run lightweight wheels and semi slicks - $1500
Upgrade (with bigger) front discs and callipers $1000.
I reckon that might be a goer. Cheap , fun track car.
Any other opinions for a good, cheap, fun track car ?
Cheers,
https://www.sau.com.au/forums/topic/129989-cheapest-most-fun-track-day-car/
  • Replies 79
pulsar for $2k.. CA18det sho'ed in for another $3k or so..
couple of $k on suspension. Would go pretty well (pushing 200kw) and weigh around 1000kg
I think in the 1.3L you'd be lacking in torque on the GTI, and they are quite overpriced for an old car.
Any old commo you could probably buy for $1-2k and spend another $5k on racing mods, and might be ok.
MK 1 Escort. You can buy a log booked, 2L caged car for the money you are looking to spend. At abour 800kgs and aboiut 160hp from a well sorted 2L Pinto they are respectable performers. You can always throw a CA18DET in there, but they just throw more weight in the things
does it have to be road registered? cant u have an econobox for daily duties? this owuld open up your options enourmously for a track car. althoough you then need to budget for towing etc.
non registered track cars:
HQ/VN/VP/EA race cars arent all taht dear i dont think
race only RX7/skyline/WRX
F3000/open wheeler thingos
and then there always bikes if u just wanna go fast real cheap, but there is the downside of being like 30 times more likely of being killed on the roads....
cortina with 250 crossflow 4.1L $1-2 grand they weigh about 1.1 tonne
turbo $3 grand
and some decent tyres. great car to drive and do some doeys in
With $8k
Mini Clubman+Mods
S1/2/3 RX7 (I doubt youd get a track worthy FC for below $8k)
Ford Escort+Mods
Gemini+Mods
Mazda 808 with a rotary conversion (RX3 setup)
Toyota Corrolla, the square early 80's one. Conversion and mods
Doubt you'd get a track worthy CA18DET S13....
Commodore might be a good thing.
R31 - ha ha ha -
I wouldn't want to trailer a car - too much hassle then there is what do I trailer it with ?
Escort might be good - RWD if def a better option.
Would want to keep the car nice and light - so no Hq, Commodore etc
I've seen some of those Honda's you are talking about Bob - They are quick circuit cars.
The Swifts did OK at Bathurst - for their category. Make them light enough and the 1.3 wouldn't matter , I'd guess.
Just did a search on Carsales.com - no Escorts there. You'd prolly need to be in the know to get a race prepped one hey.
Saw a first gen GTI for $2000 (had a 2nd gen motor in it) - Spend $2000 on the car then $4000 in mods - got to be a good circuit car for $6K......
Keep pthe suggestions coming ! It's interesting !
Mini - ?? Hmm - think a swift would kick it.
    • I know it's been YEARS but hunting down that trunk lip spoiler!
    • Absolutely nothing wrong with a Profec or similar. He's on a Nistune, so external boost control is a better option anyway.
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
