Well i just wanted to introduce myself,i dont know if this is the right section.... but it is now. My name is Shaun =] I've been on the forums for quite some time now, never was a proud owner of a skyline until last thursday, finally got rid of my 180sx (she will be missed), now the proud owner of:
r32 gts-t
midnight blue
front mount
z0rt
air filter
r33 gtr stockies
lowered
gtr front bar, side skirts and rear pods
got rid of the ghey ricer sticker
stay tuned for more mods
Edited by LZYSKY
https://www.sau.com.au/forums/topic/130008-sarp-yo/
hey shaun whats cracken been a member for about 4 months now and never really spoken to anyone on a topic or whatever im not a computer nut but a fast car nut so might make a few stuff ups anyway ive owned lots of fast cars in my bit unger days now getting back into it i bought a r33 for my son and need to buy some parts wondering if you have got any good contacts
https://www.sau.com.au/forums/topic/130008-sarp-yo/#findComment-2404978
how do you like your 32 compared to your old 180?
my 180 came on strong, but runs out of puff on top end, the skyline has no balls what so ever on low revs but when it picks up it picks up, handling wise i think the 180 was alot better, but then again i did have suspension bits, where as the skyline its just lowered, but id choose the rb zort note over the sr rawr ne day. Over all i think i broke even, not upgrading, not downgrading.
ps thanks for the positive comments.
https://www.sau.com.au/forums/topic/130008-sarp-yo/#findComment-2406346
hey shaun, nice ride.
i also had a 180sx (now have a r33). when i had my 180 it was reasonably stock (just exhaust, lowered and a bit more boost) and i found it a little bit sluggish down low, especially when i hopped into my missus SSS pulsar (natro sr). it would pull better out of slow corners but run out of puff up top.
the r33 i have now pulls nicely from about 2500-3000rpm. never driven a r32, but would like to some time. just have to wait for someone in town to buy 1 that is in ok condition (there are 2 in town but neither would pull the skin off a rice pudding).
https://www.sau.com.au/forums/topic/130008-sarp-yo/#findComment-2406741
more like...'stay tuned for a better pic'..heh,jk
nice work looks very clean, welcome to the world of skylines...
yeah i really should add a better photo, however call me paranoid but forums are evil nowadays >=)
might have better pics up when she is up for sale in the not too distant future
https://www.sau.com.au/forums/topic/130008-sarp-yo/#findComment-2408547
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
