Hi, yes i did a search and the answer i'm looking for didn't come up.
So my question is when i did a compression check, my values were from 135 to 145, i know an RB25DET static ratio is 9:1 but this doesn't tell me if my readings are fine, How do i calculate my values to see if they are good or not?
These are my results:
1 - 145
2 - 140
3 - 135
4 - 140
5 - 140
6 - 145
Motor was fairly warm and stupid compression tester was hard to get tight but think they should be about right.
No mods other than turbo back exhuast and pod filter.
Cheers , Adam.
https://www.sau.com.au/forums/topic/130019-compression-test/
thanks for that, just put my mind at ease, was worried about #3 being a bit low.
Cheers.
Ohh and Dave we need to have beers soon. ;)
Good reading would be near 160psi, youre engine is getting a little tired but will still be good for a while yet.....
Guys, The absolute value is not that important. As long as its not excessively low eg. ~125 then what matters is how close all the cylinders are.
The reason it only matters how close the cylinders are is that every compression tester reads slightly differently. Obviously quality, parts used etc effect the result. Also the temp of the engine and the amount of voltage in the battery effects it as well.
My car showed 10 psi difference between two compression test guages within two weeks. And the second one was higher!
Those results look ok to me. Generally the cylinders you do last start to show lower figures as the batteries looses a tiny bit of its beans! Again I have seen this as well.
I wouldn't worry. Keep taking it to the track!
Leakdown test is by far the most accurate means of checking the condition of the engine. It actually tests the pressure the rings can hold as well as valves and stems.
Interesting, i wonder what SK would say about this. SK???
NFI, i will be taking it to the track as often as i can. Its got good power for a stocker, at SAU dyno day it made 175rwkw so not too shabby. When i did the comp test it was in this order 1, 6, 5, 4, 3, 2, why??? i was just go front to back but then tought that number 6 is the one that stuffs up, usually, so...
How do i do a leakdown test??? do i need to take it to a mechanic?
Just noticed wrxhoon is watching this thread. I think he will give you a much better explanation than I can. I learnt all about this from him.
Leakdown test you need an aircompressor and a special air tool. Best taking it too a good mechanic. I wouldn't worry though as if you are making good power all signs point to a pretty good engine. I would start to worry when it starts burning oil or starts to not make power.
1 - 145
2 - 140
3 - 135
4 - 140
5 - 140
6 - 145
Cheers , Adam.
Adam, my motor was getting the same readings last time it was checked at UAS..
still makes good power, and nearly 0 blow by in the catch can ..
still made 294rwkw @ 18psi
Nfi made a good point on battery voltage. The two you tested first, when battery would of had more charge are the highest readings.
Try it again going in reverse order from lowest reading cylinder to highest and see if theres a difference?
And as mentioned, a leakdown test will give a better indication of engine health.
these tests look fine. Even if one cyl. is a bit low some carbon bulid up etc can cause this...
leakdown for more accurancy but really you only need to do ti if u find a problem with the compression test to pin-point the cause of the low reading.
Number 3 looks a little on the low side in comparison with the others. Assuming you have a good gauge , done the test when the engine was at operating temp ( very hard without geting burnt), the starter, battery were good and had the throttle wide open then all cylinders read low, they should be around 170 psi.@300rpm
khunjeng: carbon built up will increase compression..
Actually test was done when the motor has cooled abit so i wouldn't burn myself, and the throttle was shut, I will do it again and post new readings.
Yeah good point about the battery. Thats why I have the car hooked up to a battery charger whilst doing the tests. I wait 5 mins between each cyl so the battery gets topped up.
Btw also some readings may be artificially high if there is a lot of carbon deposits (raising the comp ratio).
With WOT the redings will be higher, make sure you keep cranking the engine until compression stops rising.
A fully charged 40+amphour battery should be good enough to complete the test, make sure all the plugs are out before you start the test.
Busky2k, they are not 'artificially' high if you have carbon built up, the combustion chamber is somewhat smaller so compression will increase. Same as if you shave the cyl head or block or even have a thiner h/gasket.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
