Hi, yes i did a search and the answer i'm looking for didn't come up.
So my question is when i did a compression check, my values were from 135 to 145, i know an RB25DET static ratio is 9:1 but this doesn't tell me if my readings are fine, How do i calculate my values to see if they are good or not?
These are my results:
1 - 145
2 - 140
3 - 135
4 - 140
5 - 140
6 - 145
Motor was fairly warm and stupid compression tester was hard to get tight but think they should be about right.
No mods other than turbo back exhuast and pod filter.
Cheers , Adam.
https://www.sau.com.au/forums/topic/130019-compression-test/
thanks for that, just put my mind at ease, was worried about #3 being a bit low.
Cheers.
Ohh and Dave we need to have beers soon. ;)
Good reading would be near 160psi, youre engine is getting a little tired but will still be good for a while yet.....
Guys, The absolute value is not that important. As long as its not excessively low eg. ~125 then what matters is how close all the cylinders are.
The reason it only matters how close the cylinders are is that every compression tester reads slightly differently. Obviously quality, parts used etc effect the result. Also the temp of the engine and the amount of voltage in the battery effects it as well.
My car showed 10 psi difference between two compression test guages within two weeks. And the second one was higher!
Those results look ok to me. Generally the cylinders you do last start to show lower figures as the batteries looses a tiny bit of its beans! Again I have seen this as well.
I wouldn't worry. Keep taking it to the track!
Leakdown test is by far the most accurate means of checking the condition of the engine. It actually tests the pressure the rings can hold as well as valves and stems.
Interesting, i wonder what SK would say about this. SK???
NFI, i will be taking it to the track as often as i can. Its got good power for a stocker, at SAU dyno day it made 175rwkw so not too shabby. When i did the comp test it was in this order 1, 6, 5, 4, 3, 2, why??? i was just go front to back but then tought that number 6 is the one that stuffs up, usually, so...
How do i do a leakdown test??? do i need to take it to a mechanic?
Just noticed wrxhoon is watching this thread. I think he will give you a much better explanation than I can. I learnt all about this from him.
Leakdown test you need an aircompressor and a special air tool. Best taking it too a good mechanic. I wouldn't worry though as if you are making good power all signs point to a pretty good engine. I would start to worry when it starts burning oil or starts to not make power.
1 - 145
2 - 140
3 - 135
4 - 140
5 - 140
6 - 145
Cheers , Adam.
Adam, my motor was getting the same readings last time it was checked at UAS..
still makes good power, and nearly 0 blow by in the catch can ..
still made 294rwkw @ 18psi
Nfi made a good point on battery voltage. The two you tested first, when battery would of had more charge are the highest readings.
Try it again going in reverse order from lowest reading cylinder to highest and see if theres a difference?
And as mentioned, a leakdown test will give a better indication of engine health.
these tests look fine. Even if one cyl. is a bit low some carbon bulid up etc can cause this...
leakdown for more accurancy but really you only need to do ti if u find a problem with the compression test to pin-point the cause of the low reading.
Number 3 looks a little on the low side in comparison with the others. Assuming you have a good gauge , done the test when the engine was at operating temp ( very hard without geting burnt), the starter, battery were good and had the throttle wide open then all cylinders read low, they should be around 170 psi.@300rpm
khunjeng: carbon built up will increase compression..
Actually test was done when the motor has cooled abit so i wouldn't burn myself, and the throttle was shut, I will do it again and post new readings.
Yeah good point about the battery. Thats why I have the car hooked up to a battery charger whilst doing the tests. I wait 5 mins between each cyl so the battery gets topped up.
Btw also some readings may be artificially high if there is a lot of carbon deposits (raising the comp ratio).
With WOT the redings will be higher, make sure you keep cranking the engine until compression stops rising.
A fully charged 40+amphour battery should be good enough to complete the test, make sure all the plugs are out before you start the test.
Busky2k, they are not 'artificially' high if you have carbon built up, the combustion chamber is somewhat smaller so compression will increase. Same as if you shave the cyl head or block or even have a thiner h/gasket.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
