Hi all,
Its been a while since i've been on here as I sold my 34GT-t. Now i'm looking at selling my current car and returning to the Nissan fold. My question is this, what benefits does the R33 GTR have of the R32 ?? Am I still able to pop the ATESSA fuse on the 33 and put it into RWD mode on the 33 ?
Chris
https://www.sau.com.au/forums/topic/130024-choices/
or get an attessa controller bluprint :thumbsup:
advantages the 32 has over the 33.
stock, the 32 beats the 33 performance wise.
obviously the 33 has slightly more responsive handling etc due to steering upgrades etc.
but the 33 interior is a bit, disappointing really.
I have been looking at both recently and read many reviews. They say out of all 3 gtr's, the 32 is the most chuckable, and it's also the most fun to drive out of all 3.
Match that with good prices, great performance, the best looks IMO (34's rank second just because they're so aggressive but I think they are too big) and the ability to pop the fuse (if you want) then you have a great car.
Attessa controllers to disable the front drive on 33's and 34's CAN be expensive, but I would view it as an investment to greater handling at the same time as you could then tweak the 4WD better and create a better handling car for road / circuit use.
GO THE 32 :dry: I am.
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2405296
ALL GTR'S ARE EXPENSIVE TO FIX.
:thumbsup: you should know that by now.
as for the age. I'm getting a 94 model because like you I was slightly concerned with that. But seriously, anything old can be upgraded or replaced. If the interior gets tired, re trim it. If the body is in bad nic, re do it.
Everything comes down to money.
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2405628
:) you should know that by now.
Yeah, this is true. I'm currently driving an 02 STi, but want to return to RWD (i like skids :no:). I was looking at an FD RX7 but they are still priced too highly. The GTR seems to be the best all round car for what I want.
Edited by Binky1970
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2405735
for the R33
Age
looks more modern (way better in my opinion)
R33 has a upgraded ATTESSA system its a faster car around a racetrack in factory form
R33 is more refined / comfortable
For the R32
slightly quicker in a straight line.
hardcore racer
more fun to drive
Have a read of the specs on my website.
http://nissanskyline.6te.net
cheers
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2430780
I don't like the way people seem to love 32's cos they are "faster" Only in a straight line. Around a race track a 33 and 34 GTR would be faster. Nissan wouldn't of gone backwards. Anyone can redline a car and drop the clutch it takes a bit more skill to go around some corners.
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2431670
Bang for buck go a 32.
Faster isnt always better. Im old skool love the look. Dislike the 33's would rather a 34. but since i cant have that (well i can but i choose to see the world instead.. hrrm hard choicce) im saving my pennies for a 32. well i aint saving. I told my boss id stay if he gave me 10K cash in hand in january! lmao whe i get back from OS he said ok son
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2432565
But you have to remember if you do the same mods on a 32 as a 33 the power gained will be greater on a 33. Same goes for the 34.
Chris
Ummm why is that? all have rb26dett, obviously minor upgrades from one to the other, but i dont understand how you have come to this determination...
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2432852
Better: engineering, turbo's, intercoolers, dump pipes, etc.
If you still dubt it, look in HPI issue 51 ;)
PS: If i had to choose between a R32 or R33 GTR, i would personally go for the R32. I love my 33 GTST, and chose a 33 over a 32 GTST, but when it comes to GTRs i always prefered the 32.
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2433133
If they were all the same why would people lash out and spend money on a newer model. As they other guy has stated things get revised with a each model you dont think they would be exactly the same do you?
Chris
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2434589
Chris
Of course they are not the exact same and i never said that, and obviously people will pay more for a newer model, but i would have thought, that the basic engine is very similar and to say that a 33 gtr will always respond better to mods than a 32 gtr (especially when you consider the weight of the cars) i would not have agreed with.
Also I would consider the fact that the 32gtr in straight line was quicker than the 33 to start with.
https://www.sau.com.au/forums/topic/130024-choices/#findComment-2435047
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
