yes.there was a really noticable falloff of performance when putting the pod on.when i put the box etc back on it was quite a bit better again than before because i had painted it with the thermal paint & put the insulation on the outside as well.the car just seemed that much more responsive & stronger,if that makes sense?
cheers
warrick
the standard air box with better filter is so much better.
costs next to nothing and is designed properly...
not something you rig up yourself..
I'll never do a pod filter again on any car I have.
there are exceptions though..
sometimes people get FMIC and the piping prevents you from using the standard air box..
this I can understand..
cheers
warrick
Sounds interesting Warrick.
My experience has been the opposite though. With the POD in it feels more responsive [aside from the noise]. I put the standard airbox back on recently just to test and it not only felt restricted [less responsive] but the max boost pressure dropped also! There were no other mods at the time - or manual boost changes.
I guess it may not be a good comparison though, between a Naturally Aspirated car and a Turbo [VT versus GTT in this case]?
I am not an advocate for pods but in my experience its a better performer over a stock airbox [this includes hi-flow panel filters too].
I have made a partition for my pod and even after several hundred kms of driving it remains fairly mild - warm but NOT hot!
let me qualify what i said though.for the first say 5 mins the pod did seem good but once you got the hot air around the k&n setup felt much better.it didnt seem to alter no matter what the temp but the pod altered considerably.dont get me wrong i have nothing against a pod but what i'm saying is if you are going to have one to get the full benefit all the time you need to have it enclosed with cold air plumbed in.
cheers
warrick
yes but how much $$$ did this cost?
My pod and partition setup [DIY] has so far cost me approx $50
A 'pro' setup will be at least $200 from what I have seen :(
One day, a nice ARC box would be nice :P
or one of these BMC ones http://www.autospeed.com/cgi-bin/browse.cg...duct=1004620002
Originally posted by sewid
Check out my Cold air partition site here with my now completed partition. Lots of pics.
http://www.endusk.com/skyline/caip/caip.html
Now that looks impressive.
When I put my pod on I noticed a drop in bottom end torque but once the revs got up i could feel it was a bit better (which makes sense as the pod has a bigger surface area than the stockie).
A few people have metioned that the stock intake has been designed really well (which makes a lot of sense since any R&D dept of any car manufacturer is full of $$$). So, bigger surface area + well designed intake = the way to go.
Yes?
I never said that STOCK filters were good.
I said the stock air box.
I put a TRUST filter element in my standard box.
MINES group in Japan always keep the stock air box in their cars.
if you haven't already seen it, see if you can get your hands on a copy of Best Motoring Number 5 (I think)
Take a look at the MINES GTR...
just a quick question.. Now that you have partitioned the air filter from the heat.. what about the pipe that goes to the turbo? wont that be absorbing the heat again? Why dont you wrap that with heat wrap? I did this setup on my other car(original box, with k&n flat filter, and larger intake pipe), and it seemed to run better with the heat wrap.. ?? any ideas?
I didnt actually mean wrap the turbo with heat wrap, just the piping to the turbo. On my mazda, the intercooler is some 3 times as big as this silly nissan one, and thats standard aswell. so, i guess that might affect the comparision aswell.
i was refering to the piping dude... you gotta think about what it does with the heat but shielding the piping, it holds it in, add's stress to localised parts due to excess heat internally, however drops underbonnet temps and mor eimportantly intake temp around filter... personal decision really, if you have a good sealed box around your filter you wont need it, but good thought tho.
Guest Robo's
Personally , i dont think the standard airbox is upto scratch, coming from other cars, where the airbox is much bigger than the turbo pipes etc. Remember the biggest restriction is your first restriction. The over the radiator duct, is good, but doesnt look big enough to supply enough volume of air. If you had another duct coming up from the front or something, that would be nice. Time for some planning.
I rang Purple Pig, they have some form of industrial rubber(9mm thick) which i could use as a divider. Anyone tried this, it is rated 70-80 degrees, is that enough?
i think what mtopxsecret6 means YBSLO4 is to wrap the piping from the airbox to the turbo so the cold air in the box is kept cold all the way to the turbo before it gets heated.i think if the air can be kept as close to the outside ambient as possible before entering the turbo it must help the intercooler do its job that much better.please correct me mtopsecret6 if i misread what you meant.
cheers
warrick
Guest Robo's
cheers
warrick
Sounds good in theory. Ok how long is the pipe, maybe 30cm, how fast is air travelling? How much will heat effect during this period of travel? I dont know. Well if you can stop it , excelent, all too help that little old intercooler.
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
    • Good work Pete and glad the car held up well....been a while since I've seen you try properly
    • Just quick update, I've had tech issues and so a backlog on life stuff....I will pull lap times from the video and data from the ECU logs to do a proper update. But basically, in order of importance: 1. The car was excellent fun on the track, really felt a lot like the good old days. And nice to have AC while waiting 2. Coolant got really hot; again I need to pull and analyse the logs but the standard system is not up to tracking at 30o+ days, once the system was heat soaked after the first 2x15min sessions I could only do 3 laps before it got 110+ and I had to cool down. If I can't improve that it is a deal breaker 3 Oil temps were fine all day, noting it was short sessions due to 2. I think it will likely need work 4 Biggest surprise AT temps were fine, never went over 100, I would have been OK with 120 before I was too concerned. The auto sucks compared to a manual (of course) but it is faster to launch and I just need to downshift it manually before hitting the throttle, then it was OK. When I post the vids you'll hear it telling me off (beeping) for trying to downshift too early (it needs about 3500 before it will downshift, depending on gear a little but we are mostly talking 3/2 and 4/3) 5 A052s were not great which hurt the lap times, but I will be constrained in what I can get in good tyres that fit the wheel wells. These were small for a heavy car at 235/45/18. In theory I can fit 9.5 on front and 10.5 rear (so not square) but I still need 670mm+ high tyres in good brands. 6 Standard shocks/springs/roll bar are too soft for track work (of course), but that was always on the list. And happily, no white on the mat, despite having a teenaged passenger, extinguisher mount was fine. Also, it was nice to have Wakefield Park back in action  . Because the car was so quiet it is eligible for Green Day, which I thought was a band but is apparently a series of cheaper practice days they run with a lower sound limit, that is a smart idea.
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
