well its not very long admittedly but have you ever put your hand on it after having been for a drive.yes the air is going thru very quickly but your still getting an awful lot of heat soak in there.same as your airbox does & its not as close to that damn hot turbo as the inlet pipe.besides for the little cost involved why not every few degrees colder the air is the better.
cheers
warrick
Guest saiyaman
howdy peoples, Ive been reading your posts....... Im sure that the partition would help with temperatures from the engine but through the tests that you guys have done it looks like the most benefits came when you reached certain speeds and that's when the air was the coldest..... so what I mean is if you could force more air into the box or pod at lower speeds in the first place then wouldn't that give you the most gains?? has anyone tried making a larger feed where the air first enters and testing what kind of difference that makes....I looked at the bottom of my bumper and the inlet is tiny, what do you guys think?
Originally posted by warick
the car just seemed that much more responsive & stronger, if that makes sense?
It makes perfect sense now :D
To all those people with a stock air box and thinking about ditching it for a pod, dont!!
I initially had the stock box on with crap filter. I then upgraded to a pod (out of peer pressure really) and was impressed with the performance gains at high revs. I was at Autobarn on the weekend and decided that I'd give the panel a shot just to get some personal closure on the issue.
After driving the car round all day with the new panel filter in I cannot understand how I put up with the pod for so long. The car gets-up-and-gos heaps better. The best way to describe it is to have a look at the boost gauge. The needle jumps when you push the throttle, before it was a little limp. A lot more throttle response :uh-huh: and out performs the pod at every rev!
Smoother, quieter, stronger application of power... How can anyone argue?!?!
Moral of the story: Pods are a complete waste of money without CAI & induction noise is bloody annoying!
You can buy heat proof cold air box foam from Unique Auto Sports. It comes with a template drawn on it so all you have to do is cut it out and attatch it. Its $90 and comes with a tube of Silicon to get perfect seals round your turbo piping and a rubber strip for along the top to cushion it up against the hood.
You may be able to source the foam yourself...its black/grey with silver foil type stuff on one side. I bought it but didnt ever get round to fitting it and ended up selling my car when I came O/S.
I would have expected a good result too as I had 198kw/atw with only a little more boost, full exhaust (turbo back) and a K&N. That cold air was much needed!
I've have just upgraded my K&N panel (now for sale if anyone interested) to an Apexi pod (had no choice, new front mount crossover pipe fouled) and have made a box for it but it is still noisy as hell at half throttle accelleration between 3000-4500rpm. Above that it goes fairly quiet again. Whats up with that? Is there any way to make it quieter?
Ok, despite the horrid review by riggaP, YBSLO4, can I still get one of those aluminum cai things your making.
Why arent I reverting back to panel you may ask? well, I bought the a trust pod filter recently, and I stand by it.......
YBSLO4, how should I go abouts in getting hold of one. Thanks!
Here is a pic of the new box I made for my Apexi pod. After lining inside with a layer of 10mm insulation foam with silver heatsheilding on one side I am more than happy with the result. Much quieter than without and a definite improvement in response. Took me a couple of arvos to knock it up out of aluminium plate, total cost under $30.
Zman: Both my pod and panel are K&N and are made from the same material so I guess it comes down to surface area. The panel is only marginally smaller than the pod and I doubt anyone would be able to feel the difference.
The panel feels like it flows HEAPS more air than the pod without a CAI.
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
