Hey peoples,
I've found that even tho the help from these good peoples with all their designs is an excellent source of information (thank you all) but the problem lies when people use different brand air filters that they don't all fit i.e. Me LOL Anyway, i will be designing one for my R33 GTSt very shortly and making a mould of it and then constructing it from fibreglass to make it light, visible and mainyl to test its resistance to heat as i cna't see it soaking as much as alluminium. The best part will be i can make it perfectly moulded to the bodywork for a very neat finish. Anyway, once its done i will post pics on here and will probably be selling them if they work well and comply with a lot of commonly used airfilters i.e. HKS, K&N etc. So if anyone is interested i will be doing them cheap jus cos i want to see a lot of confused people happy with a good product :D After all who'd pay over 100 bucks for a brand name partition?? Not me lol. So they will be very well priced, basically not much mroe than materials. But i'll let you know once the product has been developed. Thnx J.
yeah once i get my car back mine will be made with my k&n filter i'll give it ago
we have a massive gillatene (spelling) at work we used when we used to make security doors now we just use it to cut ply if we need it, and im pretty sure i can get sheet metal of some type at trade price but yeah i'll see how i can make one u never know maybe for the people in melbourne i can make some for u guys :D
Doxximus: I dun mind doin it dude :P All for the fun of it guess... And i dun min dhelpin others with things i have found to be tricky. Going to start constructing a frame/skeleton for the fibreglass probably this week depending on time, but it looks like i'll be fine. I am using a rather large K&N high power Pod filter so its porbably the largest pod filter availabe therefore will be good for everyone else because they wil obviosuly have a smaller pod which means they will hopfully all fit? I'll design it as universal as possible for all filters. And as i said it will be moulded well intospace there and will be able to be pained in any color i.e. Vehicle color etc as itis fibreglass.
That looks sweet Devo, and thats exactly what I'd be looking at doing. I thought long and hard about an induction setup from the front bar but after last Friday night when I was driving through water that was over my front bar (loads of rain) I think it's best to keep the stock intake as it stays high and dry.
I have an R33 with an Apexi filter also, do you have the template for your design Devo ?? What material did you use ?
No template as such Jimbo, it was pretty much design and build.
The partition and lid were made from 1.2mm ali and the snorkell extension was .4 or .6 ali, plus a bit of 12 x 12 mm angle at the partition to lid joint and some single sided sticky foam to fill the gaps.
B T W slide the return fuel cannister thingy of its bracket,get rid of the bracket and re-mount the canister to the partition,( I used a cable tie) this gives you a bit more room to play with.
p.s. If you make up a pattern of the partition out of cardboard, it will save you a lot of wasted ali.
Cheers
Harry:cool: :D
Just took her out ;) ... more like :):D Its looks sweet, no resin touched the body at all and the plastic liner peeled off without stickin aswell ;) I had an idea aswell, i'm covering the outside of the patition with heat reflective material, the stuff u find on sun shields for front windscreens etc. This should block alot of the heat out and soak up whatever tries to get in as they are good for around 55-60 degrees which is similar temps seen around the engine bay. Its just finishin off drying now should be ready by the morning i reckon, hopefully have it fully fitted tomorrow somtime.
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
